Old 06-24-2019, 11:19 AM   #1
1998 28' Excella
Sechelt , British Columbia
Painting interior walls and ceiling
Hi guys.
New to airstream ownership. Super stoked. Just bought a 1998 excellent 28í. And remodelling the twin bedroom to a queen.
Iíve removed all the vinyl and mouse fur and want to fill all the screw holes and have a semi smooth finish so I can then paint it all white. Any suggestions on the process. I was thinking of a thick type paint that will hide any imperfections.
Thanks for the advice.
Airyachting is offline   Reply With Quote
Old 06-24-2019, 12:01 PM   #2
1988 29' Excella
Austin , TX
We just finished painting our interior a couple of weeks ago. We had vinyl walls and the process we used was...
1. Clean the walls.
2. Fill all holes with Bondo.
3. Sand the vinyl.
4. Clean walls a second time.
5. Prime with Kilz.
6. Paint with good latex.
We also used rattle cans to spray paint end caps and trim. Some of the steps may be different for your trailer so nice you donít have the vinyl.
Weíre pretty happy with the end result.
JohnnyAustin is offline   Reply With Quote
Old 06-24-2019, 12:07 PM   #3
1988 29' Excella
Austin , TX
Below is a more current picture after painting the shelf in the end cap and spraying the plugs and screens.
Old 06-24-2019, 10:17 PM   #4
1998 28' Excella
Thanks for the reply. Yours looks great by the way. I did test about the mouse due and vinyl and have filled all unnecessary holes and primed everything. I’ll do 2 coats primer and a couple coats of a good quality paint. Then build custom bed frame (so my wife and I can sleep in the same bed). Lol. And cabinets. Wish me luck. Thanks again.
Old 06-25-2019, 09:48 AM   #5
DRJJL
1985 31' Sovereign
Poway , California
Has anyone rattle can (oil based paint) painted end caps with long term success, say 10 years or more? I’m concerned about life of this.
drjj
drjudy is offline   Reply With Quote
Old 06-25-2019, 09:52 AM   #6
DRJJL
1985 31' Sovereign
Poway , California
Look into options on Queen bed. We went from rear bunks to full (or short queen) using a hydrolic lift system, slats and foam mattress (from a popular Swedish company with many locations in California). We now have storage under bed.
drjj
Old 06-25-2019, 11:37 AM   #7
1992 21' Sovereign
Winterville , Georgia
Attachment 344327
What did you do to prep the end caps for painting?
EPEisenman is offline   Reply With Quote
Old 06-26-2019, 03:44 PM   #8
DRJJL
1985 31' Sovereign
Poway , California
Our endcaps are cracking pretty bad.
drjj
Old 07-08-2019, 10:37 AM   #9
1988 29' Excella
Austin , TX
Sorry for the slow response. I just now saw your post.
I simply lightly sanded and cleaned before painting. I used a 120 grit sandpaper and I would now recommend using 220. The 120 left some scratches that still show after painting. They're not at all bad and you pretty much have to be searching for them to notice, but if I did it again, I'd use 220.
John
Old 07-08-2019, 10:56 AM   #10
1988 29' Excella
Austin , TX
Are you saying the plastic is cracked? Ours are cracked in the corners below the cabinet. There were also other cracks in various places. I used WELD-ON for ABS to repair the cracks. It contains MEK which will melt and bond with the plastic. There are other threads on the forum about using MEK to repair the ABS plastic.
My results were mixed. The repair to the bottom corners of the cabinet did not hold. Once a little stress was re-introduced, the filler cracked. My long term solution to this is to use a piece of aluminum angle along the bottom edge and provide a support arm running down below the window. The aluminum hides the crack and the support should remove the stress to those joints.
For the other cracks, the WELD-ON worked well. I had to sand down the filler but once painted they are not really noticeable. Since there's no significant stress on these cracks (they all tended to originate from where rivets were used to secure the endcap), I expect them to hold.
If you go this route, you should drill a small hole at the end of the crack to keep it from cracking further and cut a V into the crack in which you apply the WELD-ON. Also, you should use protective gear. I actually purchased a full face mask/respirator off Amazon for the job. About $75 dollars and I love it. Works great, easy to get on/off, comfortable, and has been used a lot.
John
Interior walls and ceiling cleaning Olegus Interior Restoration Forum 20 11-23-2015 09:03 AM
Adding wood paneling to interior walls/ceiling CTdave2000 Upholstery, Blinds, Walls & Interior Finishes 2 04-01-2015 08:42 PM
Black Spots on Interior Walls, Ceiling Billie Bob Upholstery, Blinds, Walls & Interior Finishes 4 07-31-2010 09:33 AM
Painting interior walls, trim jkrauk General Interior Topics 9 01-01-2009 07:44 PM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
