Old 03-20-2008, 09:42 AM   #1
1968 28' Ambassador
GRAND JUNCTION , Colorado
Paint And Panels
I have a 67 AS I am trying to recondition a bit. I would like to purchase some aluminum panels for some old patch work, also replace an entire panel just behind the propane tanks. I also want some of the AS blue paint.
AZAL55 is offline   Reply With Quote
Old 03-20-2008, 10:16 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Welcome to the forums from the eastern slope!
Replacement aluminum (2024-T3) can be purchased from most aircraft metal suppliers, like http://www.airpartsinc.com
Most have found that Rustoleum 'Royal Blue' matches the AIrstream blue you are looking for.
Shari
Old 03-20-2008, 01:55 PM   #3
InsideOut's Avatar
1956 22' Safari
Images: 108
BTW, the thickness is .032 for the exterior skins.
Shari
Old 03-20-2008, 03:27 PM   #4
The panel behind the LPG tanks should be .040.
Airstream increased the thickness sometime ago, to stop that front panel from cracking.
Also, double up the number of rivets that hold that front panel on to the steel plate.
Old 03-24-2008, 06:32 PM   #5
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
Good thread. My 2 cents: Be sure to specify and buy Alclad 2024. All aircraft 2000 series is supposed to be alclad, but you may still find non-clad 2024 sheet goods from surplus suppliers and local industrial suppliers. I made this mistake once. I replaced my front panel in the Caravel years ago with 0.040 T-6 alclad because I had it left over from my airplane restoration days; it's a lot less likely to dent, but DO NOT try to form it.
Andy may have better feedback than mine because he gives warranties!.
WLJ
WLJ1943
WLJ1943
wlj1943 is offline   Reply With Quote
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
Under Panels jperryfly Belly Pans & Banana Wraps 31 06-30-2004 09:35 PM
refrigerator panels eraffety Airstream Motorhome Forums 2 03-31-2002 11:20 PM
