Old 01-05-2009, 12:32 PM   #1
1963 16' Bambi
Wells , Maine
Packing tape stuck to my bambi
I am having a hard time with old packing tape stuck to the sides of A.S. Any good solvent? this stuff is really bonded!
Bigtuna is offline   Reply With Quote
Old 01-05-2009, 01:11 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Assumption> 1963 = no clearcoat
First, try using Bestine it's a rubber cement thinner/solvent - it can be found at Home Depot &/or art supply stores.
If that doesn't work, try Permatex Gasket Remover which is a more aggressive which can be found at Napa or any auto supply store. Becareful though, this stuff is like Aircraft stripper - it'll burn your skin on contact.
I wouldn't use either on a clearcoated trailer...
Shari
Old 01-05-2009, 01:16 PM   #3
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
I have had some success with 3-M Adhesive remover in the red and white spray can...and WD-40.....and patience.
safari62 is offline   Reply With Quote
Old 01-05-2009, 01:31 PM   #4
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
WD-40 is a solvent and will work very well and leave no trace or damage.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-05-2009, 01:31 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I'd go with water displacement forty, like duck tape, it works on everything. Really it does.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-05-2009, 03:42 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I had residual glue left on my outer skins when I took the pinstripes off my Safari. The factory suggested plain mineral spirits. It worked and if it worked as well on my more sensitive coated skins, I think it would be mild enough to use on your vintage unit as well.
Old 01-05-2009, 07:27 PM   #7
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
If the packing tape is the plastic type, it may take a while for the adhesive removers to work. You can heat the tape up with a hair blow dryer. Hold it there for about a minute before starting. This will soften the adhesive enough to peel slowly. Carefully start lifting a corner up with a razor blade. Don't scrap like removing stickers from glass. The heat will hurt so be careful. Then use adhesive remover for the leftover residual. The appliance repair facility I used to work for does this to remove the model & serial number labels from scrapped units.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 01-05-2009, 08:15 PM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
I also second the 'heat gun' route...I used on to get all the 30 year old stripes off our AS...
I also used these plastic scrapers that I got from Harbor Freight...
Harbor Freight Tools - Quality Tools at the Lowest Prices
These scrapers will protect the alum panels...don't get them too close to the heat gun, or you'll soften the chisel points...of course, when cooled down you can grind them 'sharp' again.
Ray & Pat; Morada, CA
Old 01-05-2009, 10:41 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I use gasket remover. It works great getting old PO silicone seal off. Don't let it linger on the aluminum for long. After you have gotten the offending sticky stuff off clean the aluminum with mineral spirits NOT lacquer thinner. Graffitti Remover works good to. You can find that at janitorial supply places.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-06-2009, 02:29 PM   #10
1963 16' Bambi
Wells , Maine
Thanks a lot i will try the heat gun next....thank you for the help!!!
Old 01-06-2009, 03:26 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
WD 40 works for duct tape and that stuff is ugly to get off, so packing tape should come off. It's relatively benign and you can't burn yourself with it.
Gene
Old 01-07-2009, 11:04 AM   #12
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I agree - try wd-40 first. No downsides to its use.
Pat
pmclemore is offline   Reply With Quote
Old 01-07-2009, 01:15 PM   #13
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
One more solvent that works is a product called Un-DU adhesive remover. Gentle enough for photographs but pretty effective even on stubborn stuffl.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 01-07-2009, 04:05 PM   #14
darlingbooks's Avatar
2006 34' Classic S/O
Parkdale , Oregon
Images: 51
We have dealt in books for around fifteen years, and have had to remove all types of stickers, tape and price tags. Every type of glue adhesive reacts differently from the others when a certain solvent is applied. I have seen WD40 spray lube used to remove price stickers from professional cookware, but this would never work for books.
The solvents that seemed to work for us on books are OOPS! (Low odor formula all purpose remover), Goof Off (The Ultimate Remover), and Detachol Adhesive Remover.
What ever the solvent that you use, it will take a few minutes for the adhesive to soften, and if one doesnt work, try another. Dont use a tool harder than plastic to scrape at the tapes adhesive. If the tape is plastic, the solvent will not soften the glue through the plastic film. Pull off the tape, best as you can, to expose the glue.
Lotso luck
Steve
darlingbooks is offline   Reply With Quote
Packing a Gun, Mister~ 53flyingcloud On The Road... 340 10-07-2009 07:40 AM
Packing Your Set-up Items SilverCabin On The Road... 16 09-13-2007 05:37 PM
Re-packing Wheel Bearings wbrownrr Axles 11 05-31-2006 12:26 AM
Any packing lists out there? 6xblessd On The Road... 16 02-23-2005 03:38 PM
