Old 11-01-2015, 10:42 AM   #1
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
Question P30 Excella door step operation
Would anyone on the forum have a wiring diagram of a 1979 excella MH 24ft
My step has ceased operation and I want to trace out the wiring to the solenoid and the switch in the door. there is a deadbolt lock that causes a flashing light on the dash when the lock is not in the locked position. the step operates from manifold vaccum. the vaccum line runs from the tank through a solenoid then terminates at the base of carb. am getting no voltage at the solenoid with the door closed. This used to lift the step when the door closed and the engine running. I need the wiring diagram to find the color of the wire that is supposed to feed 12v to the solenoid that opens the valve to lift the step in the travel position.
Frank & Lisa Sullivan
Bfrank is offline   Reply With Quote
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
