Old 04-26-2016, 02:04 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Owning Portable Wheel Scale(s)
I'm seriously considering buying a wheel scale, they are quite pricey, but I think it is a worth while investment as I could weigh each tire individually, plus tongue weight and could play around all day shifting weight around.
I have found a couple models but not sure what is best. I figure I won't spend the $5k to $6k on 4 tire scales, just one.
Curious is anyone has done this or owns a scale? Brands? Best pricing?
Not interested in being told to go across CAT Scales for $10, done that plenty.
Ted S. is offline   Reply With Quote
Old 04-26-2016, 02:45 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Of course, spending $10 a pop at the CAT Scales is cheaper than buying your own scale. But there is one distinct advantage to having your own, in that you can weigh the trailer, and tow vehicle, without ever leaving your driveway, before you trust your tires and brakes to a trailer that might be improperly loaded. Driving to the CAT Scales, you have to trust that you got it right until you get to the scales to confirm it.
I don't have one for my Interstate, but if I did I'd need one big enough for duals on my rear wheels. Something to consider if you've got duals on your tow vehicle…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-28-2016, 06:35 AM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Switz has a set. See his comments.
The Economics Of Owning an Airstream das997 Airstream Lifestyle 52 03-16-2013 03:17 AM
Day 2 of owning a 1978 Ambassador and I am already in love! Missymel Member Introductions 3 09-20-2012 06:54 AM
A Newbie Owning an AS--1976 Safari RoadDreamer2 Member Introductions 3 09-18-2012 01:27 PM
The Agony and The Ecstasy of Owning an Argosy in Jackson Hole, WY Donald Ester Member Introductions 7 09-22-2007 05:29 PM
owning a vintage 'Stream' terricomeaux Member Introductions 10 11-13-2006 09:06 AM
