Old 04-18-2016, 05:19 PM   #1
1989 29' Land Yacht
Belton , Texas
Overhaul help.
I recently bought a property that has an older airstream land yacht. Looks like it's 29-31 feet. It has been under a covered shed for about 12 years and the inside is a mess. Is there anyone that would come to granger, tx and give me a scope and estimate to renovate it.
Can't see it very well but here's the shed
brazosboyt is offline   Reply With Quote
Old 05-04-2016, 09:46 AM   #2
Boxite's Avatar
2008 22' Sport
Find a restorer who will work off photos and have it towed or wreckered there.
My experience with requests like yours is that estimaters are leary of travelling distances to perform estimates because most solicitations-for-estimates are by folks who are shopping for price... which results is an expensive waste of time for the restorer who'd better spend his time on projects already in the shop.
Sorry for the downer, just tryin' to help.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 05-06-2016, 11:29 AM   #3
Highland Village , Texas
A&P Vintage Airstream, Paradise, TX
I would check out A&P Vintage Airstream in Paradise, TX. I was able to dig in and do a lot of the work myself which was a great learning experience. I saved a lot on labor. I asked a lot of questions and there are many people willing to offer helpful direction on the Forum. Having someone else do the work can be costly but usually the end product is very nice. Hope this helps.
dleetexas is offline   Reply With Quote
Old 05-06-2016, 01:33 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome. First thing I would do is give it a good deep cleaning inside and out. Get rid of all the mold and rat poop. At least that way you can reduce the disease factor and clearly see what you are working with. Might make an inspector a bit happier also. Good luck.
MICHAEL
Old 05-06-2016, 04:15 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The real question is, "What do you want to do with it?" If you'd just like to go camping or fishing it in once in a while, just clean it as noted above, check the tires and brakes, and take it on a test run. Fix the broken stuff, wash, rinse, repeat.
If you want to resto-mod it to be your pride and joy, then get ready to open your wallet and/or roll up your sleeves.
If you want to sell it, just clean out the junk and market it as "original."
'54 Flying Cloud - Complete Overhaul Cloud 9 Repairing/Replacing Floor &/or Frame 31 10-31-2006 11:31 AM
69' Overlander Overhaul martinb321 Member Introductions 5 08-09-2006 10:44 PM
'64 Overlander, Needs Complete Overhaul... Worth It??? bechand0128 Trailer Values 4 04-08-2006 09:56 PM
Plumbing Overhaul RobinP Fresh Water Systems 13 07-23-2005 07:37 PM
total overhaul need advice nevisstudio Interior Restoration Forum 40 04-24-2004 01:51 AM
