Bought 1969 overlander LY that appeared to be in good shape and actually towed it to my back yard.
After taking out three layers of carpet I found the rear floor and frame to be rotted out. I have removed 1/3 of under belly and most of rear interior black tank.
Now following a windstorm a 7'diam limb blew down on the roof requiring me to attempt toreplace two back panels. Here are my questions if you have any sage advice fire away, i need this ready by spring and can't afford to send the work out. .\\
1. Does Airstream sell the exterior aluminum panels pre-formed or do these have to be hand made.
2. Since most of the bathroom is out should I take out the fiberglass interior wall covering?? Based on a review of this forum sounds like riveting is much easier with the inside wall removed. It is three smaller but complex upper rear panels.
3. The box that held all the hoses and elec cords is totally rotted our, do the sell these preformed or do I have to get this made? same question with the battery box?? Same question on the box that hold black water tank/ with foam? All these must have been galvanized steel and were rotted bad.
4. There is some under belly frame rust so i am going to weld some reinforcement in any hazards there. Migth add on a spare tire holder in the back, any negatives to this.
5. The plywood floor replacement seems to be an easy cut and place, what type of bolts did I grind off willmany flush mount type do?
6. The 1969 water heater probably works is this worth saving or should I just replace.
7. All my copper water line is now exposed. WHY?? are there three or four places where it appeares to be spliced with re-inforced plastic tubing, is this a freeze protection or just past repairs. Should I resolder new copper, nowe would nbe the time or is the re-inforced hosing prefrerred?
8. Removed and am cleaning my fresh and black water tank. The fresh water tank is greenish plastic and appears to be okay but I can't remove some of the mineral water stains. Also the water pump contraption looks like something out of well the 1960's it works do these have a lasting reputation or should I RR while I have access??
Thanks for any input posted?
Deano
