Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-02-2012, 07:13 PM   #1
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Question Outside electrical wire
Have an outside 50 amp connection for my Airstream. There is a small section of wiring that is exposed to sunlight and is showing its age. Any recommendations for an in place repair. Have thought of several but would like to hear from others.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-02-2012, 07:45 PM   #2
Kevin245's Avatar
Hi Tarheel,
A photo or two would be helpful in assessing the condition and providing repair input.
William C. Swinney
Old 04-02-2012, 08:19 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Tarheel
If the exposed cable is Type UF it should last 25 years or more unless it is the older (1960s) type that was not sunlight resistant. It is common for type UF to be painted when appearance is a consideration.
Old 04-02-2012, 09:35 PM   #4
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Tarhell.....If the problem with the cable is just cosmetic, you can use acetone on a rag to clean off any dirt on the cable. If the area is faded and you just want to improve its looks you can cover the cable with Marinco's Zip Sleeve Cord Organizer which can be purchased at West Marine. The device is used to cover multiple boat power/telephone/cable TV cords in a single boot.
MARINCO ZipSleeve Cord Organizer at West Marine
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Using Kool Seal on the Inside of the Outside? aluminitus Roof 44 06-18-2013 08:00 AM
Anyone know where to find the outside access door hinges? Roothawg Vintage Kin 10 05-13-2012 04:21 PM
Electrical hookups at campgrounds... goswick On The Road... 13 03-26-2012 07:25 PM
Running a wire harness? Bruce B General Repair Forum 5 03-22-2012 05:14 PM
1969 Tradewind Electrical System paul z-air Electrical - Systems, Generators, Batteries & Solar 1 03-16-2012 10:54 AM
