Old 08-22-2019, 02:03 PM   #1
2018 27' Globetrotter
Japser , Georgia
Outside Campartment Door Wire Fix
I noticed there was cut marks from the wire on the outside door hinges in the gaskets. I try not to put anything on the door when itís opened but as Iím putting stuff in sometimes things happen to hit the door. Fearing potential leaks from the gasket being cut by the wire I decided to pad the wire so it would not cut the remaining gaskets. Went to the local hardware store and purchased 2 feet of a very small plastic tubing (.41 cents). Carefully made a slit down one side of the tubing and put the wire through it. Wrapped the tubing with electrical tape. So for less than 50 cents hopefully this will rectify the small wire from cutting the remaining gaskets on my three outside compartments.
ID:	350168   Click image for larger version
Gary Collier
2019 Globetrotter
2018 F250 Lariat
Jasper, GA (North of Atlanta)
garypilot55 is offline   Reply With Quote
Old 08-22-2019, 02:31 PM   #2
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Thanks Gary Iíll be checking mine real soon!
FloydCoVa is offline   Reply With Quote
Old 08-22-2019, 03:05 PM   #3
I used 1/8 inch vinyl covered braided cable to replace the OEM cables. Protects the rubber gasket and is stronger
0557 is offline   Reply With Quote
Old 08-22-2019, 03:06 PM   #4
Bad design
Old 08-22-2019, 03:24 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thatís a GREAT idea! I have some spare 10G braided wire hanging around. Probably only need a foot on each side. Might do one in red and one in black just for fun. Great suggestion!!
Old 08-22-2019, 03:27 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I use 3M Extreme Sealing Tape...always in the AS kit.👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-23-2019, 11:01 AM   #7
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I like your method better than mine. I protected the gasket on the gasket and not the wire like you did.
Thanks for the idea.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 08-23-2019, 12:16 PM   #8
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
That looks like a poor Place to mount the end. I drilled and mounted in the side of the door frame. Plenty of clearance and no cutting of the gaskets.
Streamracer is offline   Reply With Quote
Old 08-23-2019, 12:35 PM   #9
2019 25' Flying Cloud
Gainesville , Florida
Great solution if it doesnít compromise frame integrity or lead to a leak. Please attach a pic if you can. Thx.
djbar is online now   Reply With Quote
Old 08-24-2019, 08:18 AM   #10
1986 25' Sovereign
Outside compartment door
Here you go
Outside electrical wire Tarheel General Repair Forum 3 04-02-2012 09:35 PM
wire from outside reefer panel to battery buffet breez Generators & Solar Power 5 03-14-2011 11:18 AM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
