Old 03-16-2015, 02:22 PM   #1
MLeonard's Avatar
Our Airstream leaked
We had a really rough winter in the Northeast, and we only purchased our first airstream back in October. It's a 2003 classic. When we went to check on it the other day we noticed that the rug is wet and even the upholsterer dinette benches and couch are wet. Now, I have been looking for a really good reason to get it reupholstered and take out the rug to lay hardwoods, but my husband has been adamant on keeping it all original for resale value. Are we looking at just running a dehumidifier and maybe a shop vac, or do I get to gut it?
MLeonard is offline   Reply With Quote
Old 03-16-2015, 02:25 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Find and fix the leak. Without doing thst first anything else you do is a waste of time and money.
MICHAEL
Old 03-16-2015, 03:12 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Agree with Michael, don't even think about changing flooring until you have found and fixed the leak.
Sometimes the source can be tricky to find, that water can leaking at one point and follow a contorted route within the walls before it finds its way to the floor and makes its presence known!
Check windows, seams, rivets, and caulking on anything up on the roof such as antennas, skylights, awning brackets, fans, etc. Eventually you should find the source of the leak - probably after you recaulk everything! !
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-16-2015, 03:13 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Might be worth finding a shop that performs a pressurized leak test. Sounds like you have multiple leaks.
Kelvin
Old 03-16-2015, 03:25 PM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
I'll second the above--start by fixing the leak, but in the mean time, you will want to get it dried out ASAP to minimize damage to the subfloor, growth of mold, etc.. Yes, a wet vac, dehumidifier, air mover, etc., are all going to help. If you find that your subfloor is rotting, you may have repairs that go well beyond redecoration.
As to keeping the trailer original for the sake of resale value, I wouldn't worry too much. As long as you don't make design choices that are so individualized (ie., gum-drop green carpeting) that nobody else can tollerate them, I don't think you are in too much danger.
good luck!
Old 03-16-2015, 03:50 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If you had a lot of snow on the roof, that might have allowed it to leak where it might normally be ok. I'm thinking something like a vent or a seam that leak the way a roof on your house might with an ice dam. Those leaks may be harder to find without the snow.
2012 Dodge Durango Hemi/AWD
Old 03-17-2015, 02:22 PM   #7
MLeonard's Avatar
Thank you all so much for your feedback. We had a lot of snow on the roof and that is where I think it is leaking from. We are going to work on cleaning it out and dry it up and then decide where to go from there. I might get those hardwood floors after all ;-)
Old 03-17-2015, 04:28 PM   #8
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
First step get a dehumidifier in there. When I was first dealing with my leaky mess I found a used large household one on craigslist, it worked great to pull all the water out.
I actually just pulled it out again last night because I steam cleaned all my foam with a combo of upholstery cleaner and bleach and I want it to dry out fast so mildew doesn't start to grow.
As for the leaks start at the top looking for leaky rivets and seals and work your way down. Each and every time you get a storm blowing rain from a different angle go and check on your trailer again. it took me months to get my leaks under control.
Oh and you really don't want hardwood floors in there until your damn good and sure you got all the leaks because the water will just hide under that nice high floor and rot out your sub floor.
thesignlady is offline   Reply With Quote
Old 03-17-2015, 10:29 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
my AS also leaked.. floor was damaged. I fixed leakssssss and then dried the floor completely... next, I repaired the floor with special epoxy. It is not pretty, but it is strong again...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-20-2015, 03:42 PM   #10
2003 31' Classic
Terra Alta , West Virginia
Channing,
Specifically, what epoxy and process?
Dave
wvstreamer is offline   Reply With Quote
Old 03-20-2015, 06:29 PM   #11
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
There is a "wet wood restorer" product out there that hardens soft/wet wood and inhibits further decay (best used for small spot or to allow you to patch to a small spot)
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 03-20-2015, 08:59 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by wvstreamer View Post
Channing,
Dave
I used "Git-Rot". Got from West Marine.
Here is a similar but more thorough kit
http://www.systemthree.com/projects-rot-repair.asp?gclid=CMLGjo-5uMQCFZeVfgodjr0AQA
There are things thee to kill off bacteria, mold, etc.
Send Pm if you want details.. To keep thread clean...
Help! Water leaked-How to mitigate damage Molly1973 Fresh Water Systems 3 08-21-2011 04:24 PM
Beginning our search for our Airstream leeg01 Member Introductions 10 01-01-2010 11:11 AM
Mysterious leak-It leaked,now it doesn't? shinybean Fresh Water Systems 2 06-18-2007 09:02 PM
Our First Winter With Our Airstream silversled Winter Living 9 11-06-2006 04:08 PM
Our first "big" trip with our Airstream! myboyburt Our Community 11 03-11-2004 01:51 PM
