Old 08-05-2016, 04:33 PM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Oscilating multitool to remove roof calk.
Hi all.
Has anyone used a multitool with scrapper attachment to remove some or most old caulk on roof of you AS? If you have any suggestions or tips?
Thanks.
JL
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-05-2016, 07:59 PM   #2
1974 27' Overlander
Baltimore , Maryland
That sounds like a good way to get permanent gouges in the aluminum. Buy a few of these and put them on your drill. You can stack them for flat areas or just use one to get in tight spots.
http://m.skygeek.com/3m-048011-30098...disc-3-in.html
If you're dealing with silicone, get the silicone remover available at Vintage Trailer Supply.
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 08-05-2016, 08:40 PM   #3
2010 25' FB Flying Cloud
Davenport , Iowa
Save the roof; use plastic scrapers or sharpen wood paint stir and follow up with the silicon remover and alot of elbow grease. NOTHING METAL for safety sake. Also been there.
Mike
Airtandem is online now   Reply With Quote
Old 08-05-2016, 11:11 PM   #4
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Also a heat gun or even a hair dryer can make most sealants a little less difficult to remove. The plastic or wood wedges are a great idea as well.
Dennis
dennis3751 is offline   Reply With Quote
Old 08-06-2016, 07:22 AM   #5
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
I'll repeat a suggestion I found here a couple of years ago. Go to the pt store and get some of those dried cow hooves they sell for chew toys. They say it's like a giant fingernail and that it won't scratch aluminum.
Old 08-06-2016, 04:21 PM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Even though I feel like I'm swimming against the current here, I'll raise a hesitant hand and stammer out, "I used a multi-tool to remove the leftover caulking under my A/C." That stuff wasn't just hardened in place, it was fossilized! Sure, the multi-tool with the blade on it scratched the aluminum up, but I put another layer of caulking back on, then put my A/C on top of that. Then coated the whole roof with NASA ceramic paint. I can't see any scratches...
(It worked great!)
SuzyHomemakr is offline   Reply With Quote
Old 08-06-2016, 05:36 PM   #7
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
(It worked great!)
What is NASA ceramic paint? It sounds expensive.
Dingo Girl is offline   Reply With Quote
Old 08-06-2016, 07:50 PM   #8
1974 27' Overlander
NASA ceramic paint.
I sometimes joke with my wife about caulking the Airstream and fording the river. I shudder to think what you might be attempting with your NASA ceramic paint. Re-entry from orbit?
Old 08-07-2016, 06:48 AM   #9
1972 29' Ambassador
Supertherm Multi-Ceramics paint. http://www.supertherm.net/multicera.htm
OK, it's not actually from NASA, but I guess that it uses some of the tech that was developed for the space program.
I don't know if it quite lives up to all the breathless hype on the webpage, as my Airstream can still get to over 100 degrees inside on a hot day, sitting in the sun. But I guess that every little bit helps, and it did seal my roof quite well. On a day that touching the uncoated part of the trailer instantly burns my hand, I can barely feel any heat on the painted part. It took a gallon to do the entire roof section.
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 02:57 PM
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 02:32 PM
How do I remove the roof top TV antenna? Razorhog 1974 Overlander 5 03-16-2013 01:09 PM
1994 ly gas 30 ft roof leak/ remove cabinets tescofield Cabinets, Counter Tops & Furnishings 0 07-15-2012 08:38 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 11:23 AM
