Old 08-17-2012, 07:57 AM   #1
1969 31' Sovereign
Missoula , Montana
Original tongue jack...welded on, or not?
I have spend hours reviewing threads on this forum on this topic. I still do not have a definitive answer to my question. The bottom plate is obviously welded to the frame, but do these welds need to be cot out before I can remove and replace the jack? I have attached photos of the OEM '69 setup. HELP PLEASE.
adamperine is offline   Reply With Quote
Old 08-17-2012, 08:15 AM   #2
Kevin245's Avatar
The jack should only be attached via the three bolts that are visible on the top. The bottom plate is a stabilizer and is not attached to the jack under normal circumstances. The bottom plate, or welds do not need to be cut unless the PO did something unusual.
Eleanor Roosevelt
Old 08-17-2012, 08:34 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Did it have bolts in it that you took out on the top? If so, it should just slide up and out the top. My 68 doesn't have the extra looking plate that is welded on yours, if the tube of the jack stand is welded to this plate you will have to cut it out..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-17-2012, 08:44 AM   #4
1974 Argosy 20
Kooskia , Idaho
I agree with Kevin, once the bolts are removed the jack should come out from the top. The original bottom plate is to stabilize the jack only. That said, who knows what a previous owner has done.
The jacks may fit very tightly in the bottom plate hole and rust could be holding yours in. Very liberally douse yours with PB blaster over a period of several days. Then put supports under the tongue frame rails about an inch below them, put weight on the jack lifting it an inch or so, and jump on the tongue frame. That may break the rusty jack loose from the bottom.
You could also take your trailer to Rocky Mountain Truck and Trailer, out off Broadway near the Airport. They replaced my coupler and are very capable honest, and inexpensive. I would visit them first if you have any problems and make an appointment to have them look at it. Good people.
Old 08-18-2012, 09:02 AM   #5
1969 31' Sovereign
Missoula , Montana
Thanks a lot. The tube is definitely not welded....just the bottom plat, so I will try putting weight on it after PB blasting. Good to know about the trailer shop too.
Old 08-18-2012, 10:23 AM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
As others have noted, the jack can be quite "stuck" due to rust. The fit is quite tight, and any corrosion will make it difficult to remove.
I found that supporting the tongue w/ wooden blocks and then extending the jack so that it lifts the trailer a bit helped.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 08-18-2012, 11:14 AM   #7
Looking for John Galt
Dumpster's Avatar
Banjo , Montucky
And, depending upon what you are replacing it with......
I replaced my original Super Jack last season (very sad to see it go) with something more modern. What I found is that the diameter of the newer ones is slightly larger. So I had to grind the welds to remove the round support from underneath. Just an FYI if you are replacing.
Laterz
K.C.C.O.
Just because you are unique, doesn't mean you are useful.
Dumpster is offline   Reply With Quote
