Old 10-03-2010, 10:01 AM   #15
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
[QUOTE=Kirk T;902544]
The trailer is yours to do with as you wish and I wish well in your endever, but bare in mind the below.
I agree with Overlander64, your star chief was made to handle this size trailer, and I believe that if you finished this in its current lenght you will be happy with the 2 as companions.
1) consider living space, gutted it looks like you have more than you need but once all the interior is added bath and all you will find that this trailer will shorter than you think.
2) if you are going to shorten this one is that you will have to move the axle to get center balance once you have cut out the portion you are doing away with this may cause frame issues.
3) also you have the fact of width, I may be incorrect but it looks as if the trailer gets wider in the center and the end caps may not fit properly as you move them back and the body gets wider.
Just a few other things to consider in your endeaver.
Sarge
SARGE/AF is offline   Reply With Quote
Old 10-03-2010, 12:01 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I think Sarge has a good point. It looks big empty, but gets smaller with stuff in it. Maybe you've done this, but if not, go to a dealer and see how short and medium ones feel.
Dave and Sarge have pointed out problems with shortening because of the 2 cuts needed and possible frame issues. Seems to me shortening requires expert metalworking skills. If you have them, great. If not, serious training may be necessary.
Having now looked up Star Chiefs, '54 had the chrome lines on the hood and trunk, '55 and '56 has 2 on the hood and none on the trunk, and '57 had none. I remember as a teenager I felt this was the singular thing that had distinguished Pontiacs. This may be off the point, but I see the Pontiac and trailer as a set.
Photos are of Catalina (hardtop conv.) Star Chiefs for '57 and '54. And I found the '57 pulling an Airstream. This photo was taken last year.
Gene
ID:	112281   Click image for larger version
Old 10-03-2010, 05:48 PM   #17
Kirk T's Avatar
1956 26' Cruiser/Overlander
1957 26' Overlander
Alva , Oklahoma
Gene, I have attached a few pictures of my Pontiac. I still have some stainless trim to polish and attach and front bumper caps and front park lights. Kirk
ID:	112297   Click image for larger version
Kirk T is offline   Reply With Quote
Old 10-04-2010, 08:41 AM   #18
Master of Universe
Gene's Avatar
Looks good Kirk. The '54 is forever locked in my mind as one of the snazziest cars my father ever bought, but the '57 looks nice too. By then Dad had bought a '56 Lincoln the size of Rhode Is.
Gene
Old 10-05-2010, 05:56 AM   #19
Arrowstream's Avatar
Columbia , South Carolina
Please excuse my previous comment on the look of a ten foot trailer.
http://www.airforums.com/forums/f36/...eam-31076.html
Arrowstream is offline   Reply With Quote
Old 10-06-2010, 10:52 AM   #20
Kirk T's Avatar
1957 26' Overlander
Alva , Oklahoma
Thank you all for your posts. After a lot of thought and reading your comments I have decided against shortening the trailer. I do want to use the trailer when it is finished so the room will be good. I have been sorting through posts and doing a lot of research. I hope I can learn to use the search tool better. I use the Diesel Truck Resource Forum and have a lot better luck with that search. Thank you all for your input. Kirk T.
Old 10-06-2010, 11:05 AM   #21
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Kirk T - I like it!
You can do whatever you want.
Freedom to be very creative - aint it great!!!
kennethowens is offline   Reply With Quote
Old 10-06-2010, 11:20 AM   #22
VIKING's Avatar
Boulder Creek , California
Try using the google search. It's the second one down from the top on the search tool.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 10-06-2010, 11:51 AM   #23
Kirk T's Avatar
1957 26' Overlander
Alva , Oklahoma
Hey thanks! Does the Google search search only within the forum?
Old 10-06-2010, 12:14 PM   #24
VIKING's Avatar
You get results from outside also.
Old 10-06-2010, 12:55 PM   #25
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Kirk,
The car is beautiful and you are going to end up with a striking combination when you finish the trailer!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-06-2010, 01:20 PM   #26
1972 Travelux Princess 25
Cobourg , Ontario
Do yourself a favor, sell it and buy a shorter trailer. Save a lot of work and money, as well as saving a rare trailer.
Or, rebuild it as is. They towed them with cars like yours back in the fifties. Rebuild it as new, leave out all the heavy accessories and you will be in business. If you can resist the urge to add weight it will tow as easily as an 18 footer.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 10-07-2010, 06:00 PM   #27
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Your car will have no problem with that trailer. The whole point to an aerodynamic trailer is that weight considerations are not relevant compared to a square box. You can easily run that rig anywhere you'd take the car solo. Plus, the car will not be overshadowed by the trailer as one might think. They'll both get second, third and fourth takes. A really, really cool rolling museum exhibit.
Do some research on hitch receiver blueprints. Also, CAN AM RV may be of some help per same. I would reach out to other GM/Pontiac owners of that era. Someone may well already have what you need in this regard "stored in the attic" as much work was DIY for the era. Have a look at old pics of REESE Dual Cam set-ups, they would be complementary in age & appearance.
I bought springs for my car (Chrysler) from EATON DETROIT and upgraded to HD w/AC for trailer-like loads. You'll find everything you DON'T like about the steering and shock absorbers once towing. I believe that's about it.
I see no need to shorten. That trailer -- brand new -- was likely to have been behind a car like yours. The automatic transmission (lacking a true "Park" function) was one of the deficiencies no one missed in later years. Same for 4-whl drum brakes. Neither is a concern with that trailer beyond what you are already comfortable with solo. A set of rubber wheel chocks (truck size) for both vehicles is recommended.
By the late 1960's both ATF and PSF coolers were becoming standard Tow Package parts; I'd add MAGNEFINE filters to both.
What is the rear gear set ratio? The empty scaled weight?
Very, very nice looking Pontiac!! Great colors.
(As to searches, just post it here on this thread if you are not having luck. Such a fine old car and trailer -- alone -- excites interest. From a distance we aren't the ones involved in the details, but it may be that we can offer up a thread or three. I also post on DTR and find no problem with searches here by comparison, BUT this place is huge as trailers comprise auto, house, RV and associated problems. I grew up around trailers. Trucks are easy by comparison once we eliminate the drivetrain).
Old 10-07-2010, 06:29 PM   #28
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Don't you dare! Wally will be pissed....
GREENovaters is offline   Reply With Quote
'65 Safari Major Renovation BWH-Utah 1965 Safari 57 05-19-2011 04:42 AM
Shortening a Globetrotter campercam General Repair Forum 3 07-01-2010 07:06 AM
Shortening a 31-footer ventport General Repair Forum 9 10-26-2009 01:27 PM
Contemplating... htbyron Member Introductions 15 04-21-2006 11:56 PM
Major mechanical renovation.. see it! RealShinyOne Mechanics Corner - Engines, Transmission & More... 13 05-07-2005 08:16 PM
