Old 03-30-2015, 01:04 PM   #1
Oopsy - Used 1/8bit not #30 for Buck rivet
Well, it looks like a 1/8 drill bit makes a slightly bigger hole... slightly than a #30... I did drill some holes with a 1/8 about half on one panel.
I'm guessing it will be OK... and my wife will never know.
1. Should I be freaking out about now about using a 1/8 bit and not a #30? or just keep going using the #30 on the the remaining holes? I'm not sure what else I can do. I'm sure they will buck OK for a trailer... I'm not putting an airplane motor on it.
2. In other news... I'm going up to the next size on some vintage window frames. EG. I'm planning on using 5/32"Rivets. The only Drill bit I see for that is... 5/32" right?
3. I should rivet on the Jalousie windows right? not screw them on? naaaaaa... I mean it MIGHT be easier to service the windows with screws? but I shouldn't have to if the butyl tape and everything else is good.
Thanks Again!
bass-o-matic is offline   Reply With Quote
Old 03-30-2015, 01:29 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Um, a #30 is bigger than a 1/8" bit, so I think you're perfectly safe. A #20 bit is ideal for a 5/32" rivet. If you stuff a 1/8" rivet in a 1/8" hole it just makes life hard and is not best practice.
Disclaimer: I can't count the number of times I've read on this forum that a #21 bit is better than a #20 for a 5/32" Olympic rivet. The manufacturer and most rivet vendors advises a #20 and that's good enough for me but to each their own.
Summary, you're good to go
truckasaurus is offline   Reply With Quote
Old 03-30-2015, 02:26 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Buck Rivet or Pop Rivet?
If it is a buck rivet not really a big deal, if it is a pop rivet... not really a big deal either. Though they will fit better in a #30 hole rather than the 1/8" one.
FWIW #30 is .1285" and 1/8" is .1250"... do the math
Aaron
WBCCI #XXXX AIR #2495
Old 03-30-2015, 03:15 PM   #4
Thanks guys!
it's so weird. all the numbers say that the 1/8 should make the smaller hole but with the #30 I got from Aircraft spruce and the 1/8 milwaukee bit I have the #30 is actually smaller. I think I'll drill some more test holes... something is wonky here....
26 Foot Exterior Buck Rivet Count alumascoupe Ribs, Skins & Rivets 7 12-31-2012 09:10 AM
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 09:29 AM
Buck Rivet missing heckbo76 Ribs, Skins & Rivets 5 05-22-2012 05:13 PM
Buck rivet gun question mrgreen Ribs, Skins & Rivets 8 03-16-2012 12:27 PM
Buck Rivet Tutorial sought TheProfessor Ribs, Skins & Rivets 6 05-27-2010 06:03 PM
