Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-01-2019, 08:02 AM   #1
2015 28' Land Yacht
Chapel Hill , North Carolina
On the road in Portland, OR trying to find someone to install a lift kit
My wife and I are from North Carolina and have been traveling off-and-on out west for the last 8 months. Our airstream is currently in Portland, OR and we have decided we want to have a Lift Kit installed. We will be heading that way next week to "rejoin" the Airstream!
Some of the most beautiful boondocking spots out west are down rough dirt roads and I'm tired of dragging the back of the trailer all the time. Can anyone recommend a place to have a lift kit installed? FYI, the Airstream dealer in Portland won't do it (Airstream Northwest), nor will Ultimate Airstreams, so I'm looking for another option. Or maybe somewhere in Bend (that'll be our first destination after leaving Portland at the end of next week.
I would do it myself but don't have that level of tools or "support" when I am on the road.
Any guidance will be appreciated.
Sincerely,
Matt
HappyHapgood is offline   Reply With Quote
Old 07-05-2019, 02:49 PM   #2
2015 28' Land Yacht
Bump. Anyone?
Old 07-05-2019, 03:51 PM   #3
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
DK Fab would probably do it for you, down near Woodburn.
they could make up a kit.
GK Machine could probably do it in the repair department, but they might be a bit more expensive. both do custom Fabrication.
if you want the standard Dexter Lift Kit, probably a Tire Store could do it for you also.
Six Roblee's in Portland, or Autowheel specialize in Trailer parts not typically RV, but Trailers in general. They could get the standard lift kits for you.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Old 07-05-2019, 05:05 PM   #4
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
In Bend I would suggest you check with Flyte Camp and see if they will do it. They are a trailer restoration company.
http://www.flytecamp.com/
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-06-2019, 06:52 PM   #5
1993 25' Excella
Saratoga , California
Here is the title of a YouTube showing how to do this.
Lifting Reynold the Airstream P1 - TMWE S3 E111
Looks pretty straight forward but I’m sure all must be done carefully and correctly for safety’s sake. Personally, I would have it done by folk who know Airstreams as they are more likely to be careful about jackpoints, etc.
Wissler is offline   Reply With Quote
Old 07-06-2019, 09:30 PM   #6
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
If you happen to be going through Northern California, I’ll bet Vinnie’s Airstream Repair could do it. They have a stellar reputation. http://www.vinniesairstream.com/
daleyocum is offline   Reply With Quote
Old 07-06-2019, 10:08 PM   #7
Wconley's Avatar
2018 28' International
Renton , Washington
U-Haul Trailer Hitch Super Center in Beaverton did some great hitch work for us a few years ago as well as troubleshooting a wiring problem. They might be a good source.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-07-2019, 09:52 AM   #8
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Whomever you choose for the labor I’d recommend installing the dexter kit - it’s plug and play. No need for custom fabrication. It’s one of the best / simplest upgrades I’ve done on my 30’. Good luck.
wulfraat is offline   Reply With Quote
Old 07-07-2019, 09:58 AM   #9
2007 27' International CCD FB
San Diego , California
Agreed with the Dexter kit. No point recreating with a custom fab piece.
Lift was the next upgrade ever. You'll appreciate it for much more that just clearance. Anytime you use a storage compartment, dumping tanks, etc.
It's a straightforward install that any trailer shop should be able to handle. As long as the pay attention to the jacking points.
Note that you'll need to adjust your hitch and WD bars after.
pteck is offline   Reply With Quote
Old 07-07-2019, 10:57 AM   #10
2015 28' Land Yacht
Thank you for all the very helpful recommendations. I definitely plan to use a stock Dexter kit. While it’s a simple mod, I’m on the road and don’t think I’d have the tools and help I’d need to do it on my own. I wish the Airstream dealer in Portland would do it, but they won’t (it’s at that dealership right now getting some other work done).
I’ll get on the phone on Monday AM and report back to this thread after those calls or getting the work done.
Thanks again!
Matt
Old 07-07-2019, 01:02 PM   #11
You might give Dexter a call to see if they have any recommended partner shops in the region to perform the lift.
Old 07-07-2019, 02:44 PM   #12
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
It can be hard, or easy, depending on the configuration of your trailer. On some trailers the tank pans interfere with access to the bolts/nuts to mount the kit.
Find a trailer repair shop that sells Dexter axles. They should do it for you.
I was lucky enough to have a local traveling RV repair guy that came to my storage area and did it in the parking lot. I just happened to have an air over hydraulic jack that I bought to do some brake work on another trailer. It made it pretty easy except for the interference problem.
http://www.airforums.com/forums/f437...ay-189927.html
Al
Old 07-08-2019, 10:00 AM   #13
2007 27' Classic FB
Ridgefield , Washington
Images: 11
Might want to try RV Pro's in Vancouver Washington.
John
Woosch is offline   Reply With Quote
Old 07-08-2019, 11:18 AM   #14
Caffeinated's Avatar
2015 27' Flying Cloud
Newberg , Oregon
While I agree that the Beaverton UHaul hitch center does good work, their parking situation is not one I'd bring a 28 ft trailer to.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 07-08-2019, 11:27 AM   #15
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Maybe give the Airstream dealer in Spokane a call.
Old 07-18-2019, 11:25 AM   #16
2015 28' Land Yacht
Thank you to everyone for their suggestions. I ended up getting this done in Bend by an independent trailer/RV repair guy. He was pleasant and did a good job. So nice to be up a couple more inches and have less worry about dragging our tail end.
Old 04-28-2021, 10:57 AM   #17
2018 16' Sport
Portland , Oregon
I realize this is an old thread, but wanted to post in case someone comes across it later like I did.
Just had some work completed by AANW in Portland and found out that they now install lift kits! They order the kit directly from Dexter. It's next on my things-to-upgrade list.
speednoodle is offline   Reply With Quote
Trying to find someone to help us replace part of our subfloor!Anyone know a company? Watkins2292 Interior Restoration Forum 1 01-02-2018 02:20 PM
Lift kit install east coast charlesk Jacks, Stabilizers, Lifting and Leveling 2 09-06-2017 05:56 AM
Trying to find a Kelsey Hayes - seal and shoe kit 1993 Excella atomeve Wheels, Hubs & Bearings 10 04-08-2014 08:11 AM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Trying to locate someone who sews custom curtains! jhembree Our Community 5 03-17-2011 10:13 AM
