Old 04-04-2012, 09:55 AM   #1
dznf0g's Avatar
Oswego , Illinois
Oh, Oh!
Can anyone tell me how to get the tail light housings (the cast aluminum ones) off? I have lost the LED pigtail behind the housing!
Edit: 2007 Classic
-Rich-
Old 04-04-2012, 11:27 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I'd figure it dropped and drifted to one of the side edges- I'd spend a long time trying to fish it out with skinny various wire hooks before contemplating dissecting anything!!
Old 04-04-2012, 11:59 AM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Is it the dual LED type?
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-04-2012, 02:27 PM   #4
dznf0g's Avatar
Oswego , Illinois
I finally got it. The pigtails are, NATURALLY!!!!!!!, cut too short to come out of the hole in the plastic backing "can". I had to cut the hole bigger with a Dremmel so I could get 3 fingers and a coat hanger down there. I believe the only way to get the cast aluminum bezels off is to remove the bedroom and the inner skin!
FYI, If you do need to replace the LEDs which LED4RVs offers for the late model 4 lamp Classics and similar, the warranty which Dan can get from the mfr. requires that the pigtails and connectors be in place. That's where I got into so much trouble.
If you don't care about any warranty coverage, it is FAR, FAR easier to cut the wires downstream from the connector and splice in the new lamps. It is SOOOO hard that at $35 each, it MIGHT be worth it to cut the wires and just pay if they go bad.
This was the hardest job I have ever had to do on an AS thus far!
-Rich-
Old 04-04-2012, 02:46 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If and when...I think I'll try a couple LED bulbs first. See if I like 'em.
Glad you were able to get the wiring out, hate it when that happens.
Came real close for me when I was sealing the trunk last Spring, wiring for the light disappeared, thought for sure it went behind the skin, you know how hard it is to get inside the trunk of a Classic? Finally found it behind the close-out panel, know how hard it is to get OUT?
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-04-2012, 03:03 PM   #6
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
wiring connectors
if you're dealing with physically "short" leads coming out of the hole, these connectors from Tyco (Model # CPGI-CWT-9002-15) might be useful to extend them to a more usable length.
SolderGrip Heat-Shrink/Solder Multiple Wire Butt Splices, 22-18, 15/Clam-CPGI-CWT-9002-15 at The Home Depot
I use a small butane torch to install them, and they come in larger sizes, too.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 04-04-2012, 03:42 PM   #7
dznf0g's Avatar
Oswego , Illinois
best,
Yeah, but getting to them to extend them is the issue!.. I have used those heat solder/shrink connectors before. They're nice.
-Rich-
Old 04-04-2012, 03:46 PM   #8
dznf0g's Avatar
Oswego , Illinois
By the way, if you ever do this, when you finally do get the connector semi-out, when you connect the new LED, zip tie the connector together. That way if you ever have to remove them again, you can pull the harness enough, without the connector coming apart and losing the end of the harness.
-Rich-
Old 04-04-2012, 04:12 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I replaced my LED tail lights several years ago. The factory lights were failing. I bought new lights on line and ordered the pigtail connecters too. My wires were sealed in place real good so they couldn't go anywhere, but they were pretty short. I now have all four lights connected to the pig tails with a standard three wire plug on each one. [like the trucks use]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-04-2012, 04:59 PM   #10
dznf0g's Avatar
Oswego , Illinois
Are you saying they were hard wired and butt connected from the factory and you ordered 3 prong connectors?
Mine had the 3 prong connectors already. They were electrical taped together....I guess to ensure not vibrating loose. But the electrical tape wasn't enough to hold them together to pull the connectors out.
-Rich-
Old 04-04-2012, 05:11 PM   #11
Salem , Oregon
Images: 18
Hi, yes mine were hard wired; I now have about a 6" pig tail for each light and my lights also have about 6"s of wire from the light housing to the connector.
2005 Safari 25-B
Old 04-04-2012, 09:51 PM   #12
JFScheck's Avatar
Rockville , Maryland
Images: 33
Wow - great story shared with us, and reminder that when working on your "stream" to be careful of what you disconnect and might drop behind alumni walls!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-05-2012, 01:03 PM   #13
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
hmm, sounds like a small market for "cable extenders". what kind of connectors are used? I'll bet we can find them and fab them up!
pictures, anyone?
Joseph & Gabrielle
Old 04-05-2012, 01:54 PM   #14
dznf0g's Avatar
Oswego , Illinois
Here ya go, have at it!
-Rich-
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
Repack Wheel Bearings in Cincinnati, OH jhohe Wheels, Hubs & Bearings 37 06-08-2013 06:17 PM
Oh poop! monkeypants Our Community 7 03-23-2012 07:49 AM
oh s@*^(# black water holding tank clogged happypill Sinks, Showers & Toilets 12 01-23-2012 06:27 PM
