Old 06-23-2016, 11:07 AM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Odor (?) from shower in 2014 Airstream
OK, here's the mystery... Our 23D is a 2014 model, and, as such, still pretty much delights with that "new Airstream smell" every time the door is opened. Even so, there is a ever-so-slight-but-distinct "odor" coming from the rear (corner) bath. My wife swears it smells like "pee," I contend it's outgassing of the fiberglass shower.
So, to rule out the toilet as a possible offender, I filled the [clean] black tank so that the water was all the way up the drain pipe to the toilet's flush valve... so, water was covering the entire tank as well as the toilet-to-tank seal. The water held at that level for 24 hours (ruling out a 'leak' somewhere). The "odor" in the area was unchanged.
I closed the shower door, left it closed overnight. The next morning, I went out , opened the shower door and stuck my big nose in there... sure enough, I am even more confident that the "odor" is coming off the fiberglass shower.
For the record, the bathroom is surgically (!) clean. If I sniff around the toilet, there is no indication of any stink.
I'm at a loss... mostly because my wife won't concede that the odor smells pretty much like the ancient can of fiberglass resin in my garage.
But...
Could she be right?
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is online now   Reply With Quote
Old 06-23-2016, 11:58 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Run water in the shower drain.
There is a trap beneath the floor that keeps the gases from venting into the cabin via the shower drain. In the heat, and if not used, the water can evaporate from this trap and allow the tank to vent into the shower.
To my knowledge, the shower drain in a 23' runs to the grey tank, not the black tank.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-23-2016, 12:05 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
What JD said. Pour a cup of water down the drain, that will fill the trap.
2012 Dodge Durango Hemi/AWD
Old 06-23-2016, 12:15 PM   #4
2014 25' FB International
Metuchen , New Jersey
That's an interesting possibility JD pointed out. My first thought, if you're not using a drain trap, was hair in the drain.
GenXair is offline   Reply With Quote
Old 06-23-2016, 12:20 PM   #5
RFP
RFP's Avatar
Hurst , Texas
Regards,
JD
Oops, sorry... one "fact' that I failed to mention is that the shower trap is full and the rubber drain plug' is in place.
Thanks for the suggestions, though... I appreciate your thoughtfulness.
And some stuff
Old 06-23-2016, 01:11 PM   #6
Wayne&Sam's Avatar
Images: 21
Is the shower vent open? If so you might get the smell from the tank vent if it is nearby on that model.
Old 06-23-2016, 04:32 PM   #7
RFP
RFP's Avatar
Hurst , Texas
Breakthrough!
I should have done this before I posted.
I had Linda go out to the trailer, take off her shoes, put her little [sensitive] nose right up to the fiberglass wall of the shower and 'sniff.' Yep, sez she, that's it!
Ah ha.
So tomorrow, I'm going to wipe down the shower from side to side and from top to bottom with denatured alcohol. Then I'm going to 'wax' the whole shebang with one of the new polymer 'waxes' that have become so popular for cars. Maybe I can seal in the odor.
Sure hope that's not a bad idea with unintended consequences... dang, I worry too much.
Rob
And some stuff
Old 06-24-2016, 07:13 AM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I guess if that doesn't work you are going to have to use the trailer more. Once a you have a few more showers, toilet events, and cook up a bunch of delicious food I bet the odor will go away or won't be noticed.
or you can start wearing Old Spice
Kelvin
Old 06-24-2016, 07:21 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Hang some dirty socks on the shower towel bar and that may mask the other aroma.... We waxed the shower in our 2015 23D as soon as we got it home and have not noticed any unusual smells.
Old 06-24-2016, 03:28 PM   #10
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
Use white vinegar in a spray bottle to thoroughly wet down shower. Then use Arm & Hammer in a shake bottle to coat every inch of your vinegar wetted shower. Fill a sponge with vinegar and begin washing, DO NOT rinse. Let the mixture stay on for as long as possible, a day or two, spraying with vinegar and shaking some baking soda now and then as necessary. Or at least several hours. Yes this will bubble up, fun! Kids will love it! Call it a science experiment. Not only does it removes bad smells, Bonus is that it will really whiten your tub too.
Of course there is a chance that this won't work, I've never tried it on fiberglass for smells, it will still whiten your tub. I've taken stains and smells out of plastic containers though. So at least worth a shot.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 06-24-2016, 03:35 PM   #11
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by KJRitchie View Post
<<< snip >>>
Kelvin
Or maybe drinking it... I hear it's excellent over ice with a twist of lime...
So, as a follow up, I wiped down the entire surface of the shower with a Bounty paper towel (dang, I love those things!) well saturated with denatured alcohol. Doing this removed a 'yellowish' film that I am suspecting to be some type of mold release used in the molding process. This stuff must have pretty tenacious in that it had resisted the very best efforts of earlier scrub-downs with 'Scrubbing Bubbles' and the like.
After the wipe down I used Maguier's 'Paint Protect' (Maguier's product number G36516). This stuff is a super-easy-to-use polymer sealant. The best news of all is that the offending odor is gone.
Yay, I love a happy ending!
Rob
And some stuff
Old 06-24-2016, 04:08 PM   #12
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
I have noticed the same scent in our 2016 international shower and I thought it was coming from the drain because once I use the shower the scent is gone... for awhile.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 06-24-2016, 04:20 PM   #13
RFP
RFP's Avatar
Hurst , Texas
Happy Friday, 'Beach...'
Sometime, just give it the same 'up close sniff test' we did and see what you think... all fans off, put your nose right up against the fiberglass and sniff
Ours was definitely coming right off the fiberglass shower.
And some stuff
Old 06-24-2016, 06:31 PM   #14
2014 25' FB Flying Cloud
Mattituck , New York
I was informed by AS that the shower or sing drains might dry out or splash out due to the trailer motion on the road.
Previous suggestion filling trap with vinegar which might be mixed with water seems good.
We use a spray bottle with vinegar and dish detergent to clean shower surround.
I would bet the culprit is a dry trap.
John
darsea is offline   Reply With Quote
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
That Airstream Odor???? Chasmorgan General Interior Topics 18 07-29-2012 01:31 PM
Airstream Smell or is it an Odor? woodedareas General Interior Topics 32 08-04-2008 08:53 AM
Interior Odor JMSteward 1970-79 Tradewind 11 10-13-2006 03:48 PM
Duo-Therm Penguin odor startrekker2001 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-22-2003 08:49 AM
