Old 12-08-2007, 06:31 PM   #1
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Nuts
Quick one.
What size socket fits the wheel bearing castle nut?
I can't find mine.
1995, 28" Excella
Michael
ArtStream is offline   Reply With Quote
Old 12-08-2007, 06:42 PM   #2
_
Originally Posted by Artstream
Quick...I can't find mine.
that's not the one i borrowed is it?
gave it back i swear!
but i'm sure someone will help soon,
with the sizing issue.
2air'
Old 12-09-2007, 04:28 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You really don't need a socket unless you are replacing the outer races of your bearings. You only need to bring the bearings up to a snug condition with an adjustable cresent wrench (while rotating the wheel), if you are simply repacking the bearings. After you snug them, you back them off and them up to finger tight and back off enough to insert the cotter pin. This is the proceedure recommended by Airstream in the service manuals. Overtightening them can result in bearing overheating and early failures.
If you are replacing the races, then you will need a socket to seat the races by applying 50 ft lb of torque before you perform the above proceedure to properly adjust the bearings to the 0.001 - 0.10 inches of end play recommended by Airstream.
Old 12-09-2007, 06:56 AM   #4
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Thanks dwightdt, that's the procedure I follow, but I use the socket for the snug part.
Now on my 95, it's hard to get anything like a adj. wrench or pump plier on the castle nut, cuz it's resessed in the coller of the brake drum. Also, I don't know about the older models, but my nuts are over 1-1/4".
Sure, I could remove the wheel and check, but I don't want to remove the wheels till I ready to repack.
Anything?
Michael
Old 12-09-2007, 08:06 AM   #5
1977 31' Sovereign
1989 34' Excella
Oops. I left out a zero in the second spec. That should be 0.010 inches (10 one thousandths of an inch) ( about the width of 3 human hairs) Not 0.10 inches which would be a tenth of an inch. That would be way too much.
Old 12-09-2007, 09:59 AM   #6
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
large size nuts
So Dwightdi,
Do you know the size of the socket needed for the castle nut?
Remember, it's over 1-1/4"
Michael
Old 12-09-2007, 11:34 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
So Dwightdi,
Michael
A pair of channel lock pliers should work just fine, the nuts really shouldn't be that tight.
Old 12-09-2007, 11:36 AM   #8
Images: 59
1 1/2"?
(if the spindle is 1-14?)
Nuts! Dave and Pat All Argosy Trailers 12 10-16-2007 06:53 PM
Check your nuts! thecatsandi General Repair Forum 46 10-14-2007 08:32 AM
Are we nuts? pbnjsellers On The Road... 19 06-14-2005 09:05 PM
Am I nuts? Dickwalker Towing, Tow Vehicles & Hitches 3 12-09-2003 09:00 AM
Am I Nuts? (Shakedown II) keylime 1959-69 Tradewind 14 07-05-2003 08:28 AM
