Old 05-16-2018, 09:08 PM   #1
2002 25' Safari
Shellsburg , Iowa
Normal Hot Water Flow Rates
Thanks to this forum I replaced the hot water mixer valve and dramatically improved the flow rate for the hot water. A little over $100 on Amazon. It is now usable but still about half that of the cold water. Is this normal?
Knowfun is offline   Reply With Quote
Old 05-17-2018, 08:47 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I would think they would be the same. I switched to PEX during the remodel so my trailer isn't comparable.
If you can see your piping/fittings you could count the fitting and estimate the length of pipe. There are specs for the pressure drop for your fittings and pipe. Measure your flow and that should be all you need to see if your equipment is working properly or is there a defect that is in you water pipes/fittings.
sgschwend is offline   Reply With Quote
Old 05-18-2018, 05:36 AM   #3
Lakes Region , New Hampshire
Bring that you are concerned about pressure, I expect you are talking about the shower, how is the pressure at the sink. Not knowing your specific setup, most of these are tee'd off at some point and this would let you know if there is a line issue closer to the shower
RandyNH is offline   Reply With Quote
Old 05-20-2018, 04:09 PM   #4
2002 25' Safari
Shellsburg , Iowa
The shower is first then bathroom sink and then kitchen. Sounds like the hot and cold water should have about the same flow rates. The shower actually seems a little better than the two sinks. I will check the sink aerators, they may have gotten clogged again. Thanks!
Old 05-20-2018, 04:25 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Put in an Oxygenics shower head. It mixes air with the water and gives a much greater perceived flow. And uses less water.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Low flow of hot water in bath sink? jholder General Repair Forum 0 02-25-2017 09:13 PM
Low Hot Water Flow 762x51 Water Heaters, Filters & Pumps 31 04-25-2016 05:49 PM
Poor hot water flow - new Airstream AirFoiler Water Heaters, Filters & Pumps 4 05-04-2015 12:01 PM
hot water flow in shower tapers off k5uuu Sinks, Showers & Toilets 4 04-30-2014 07:50 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
