Old 10-01-2014, 11:49 AM   #1
1980 24' Caravelle
Pocatello , Idaho
Norcold Model 510 refridgerator Door panel
I am wondering if anyone can tell me how to disassemble the door
so I can replace the decorative panel.
Dennis Proksa
Dennis Proks is offline   Reply With Quote
Old 10-01-2014, 12:01 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Remove the door. Turn it upside down. You should find the screws holding on the bottom edge. Remove those. Slide out the existing panel. Repeat in reverse to reassemble.
Note: If you don't need refrigerator magnets, a sheet of clear-coated aluminum trimmed to the right size makes an excellent easy-care door panel.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-02-2014, 10:31 PM   #3
1980 24' Caravelle
Pocatello , Idaho
Thanks for your reply. We already removed the door and tried removing the bottom and the top of the frame. neither would budge. It appears that the ends are somehow molded into the foam. I will look at it again.
I just Read your assessment of the rim frame on Perrys thread. I have a 1980 Caravelle
that I am rebuilding and I put 5 outriggers in and a rim around the perimeter. It is still in dry dock so I don't know how it will work. You can take a look in the 1980 Caravelle section.
Dennis Proksa
Vintage Refridgerator Norcold 523 walt c Refrigerators 0 07-14-2013 01:35 PM
Toilet Flush Peddle for a Sea Land 510 Tin Lizzy Sinks, Showers & Toilets 1 08-07-2006 02:24 AM
Needed, outside refridgerator panel for 79' 31' Landyacht wacnstac Ribs, Skins & Rivets 5 03-27-2006 01:14 PM
1969 Sovereign Refridgerator Door jyobp Refrigerators 1 01-25-2004 05:40 PM
Norcold Model 624????? srgntpepper Refrigerators 1 11-17-2003 09:10 PM
