Old 04-17-2014, 11:40 AM   #1
Texasgypsies's Avatar
1987 29' Sovereign
Waller , Texas
Norcold 962 Code A3
We need help. The manual says this diagnostic code means the door is ajar and interior light on for more than two minutes. Action is to close door and alarm will stop sounding ....it doesn't! We have removed light bulb . .could that be reason?
Texasgypsies is offline   Reply With Quote
Old 04-21-2014, 08:52 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Shouldn't be. A missing bulb should register as being off, not on, because it breaks the circuit same as does the switch.
If you're not using the light anyway, find the switch that operates the light, and tape it down so that the switch is always in the closed position even when the door is open. If that doesn't solve the problem, then leave the tape on the switch but put the light bulb back in. It shouldn't light up even when the door is open as long as the switch is taped down, so it accomplishes the same thing as removing the bulb did.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Norcold Blues RxRhino Refrigerators 3 01-25-2006 09:26 AM
Source for Heating Element foe Norcold 624 srgntpepper Refrigerators 2 05-11-2004 05:02 PM
Norcold Model 624????? srgntpepper Refrigerators 1 11-17-2003 09:10 PM
Norcold g/e Refrigerator Recall FLguy8 Refrigerators 1 12-06-2002 12:58 PM
