Old 03-24-2016, 09:26 PM   #1
Fullerton , North Dakota
Noises refrigerator fan
We have a 2016 25' rear bedroom. Because the microwave is above the fridge, a fan was installed at the factory behind the fridge for ventilation. The fan is very noisy. Any suggestions?
LWinters is offline   Reply With Quote
Old 04-03-2016, 05:42 PM   #2
Keith Gantt's Avatar
2014 23' Flying Cloud
Woodstock , Georgia
Name:	ImageUploadedByAirstream Forums1459726892.935909.jpg
ID:	259964Click image for larger version
Name:	ImageUploadedByAirstream Forums1459726923.061258.jpg
ID:	259965Click image for larger version
Name:	ImageUploadedByAirstream Forums1459726947.043622.jpg
The Streaming Gantt's on Airstream Forums
Keith Gantt is offline   Reply With Quote
Old 04-03-2016, 05:46 PM   #3
Woodstock , Georgia
To explain the previous pictures..
Rubber isolated mounts
Adjustable temperature control for fan
And insulated the "box walls" around the microwave that act like a megaphone and amplified the fan noise.
Old 04-03-2016, 05:47 PM   #4
Long Island , New York
Welcome to the forum!
Not sure if the existing threads cover your configuration of a noisy fridge fan, but you might want to check them out:
http://www.airforums.com/forums/f425...lly-11811.html
http://www.airforums.com/forums/f516...an-141315.html
Good luck!
Old 04-05-2016, 08:07 AM   #5
Thanks so much for your replies. I think airstream has a poor design. Irritating noise when all else is quiet. I am going to start with the rubber mounts and go from there. Great ideas. Thanks again.
Old 04-05-2016, 08:16 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My replacement fan. So quite that I have to go outside and look to see if it is even on. Click image for larger version
Name:	ImageUploadedByAirstream Forums1459865801.054181.jpg
MICHAEL
Old 04-05-2016, 09:26 AM   #7
Originally Posted by AWCHIEF View Post
My replacement fan. So quite that I have to go outside and look to see if it is even on. Attachment 260052
Thanks Michael, not sure about the fan's specs/model number. I noticed you got it at Radio Shack?
http://www.airforums.com/forums/f425...ml#post1612200
Could you please tell us exactly what it is? Looks like "FLX" at the end of the model number . . . Guess you added that On/Off switch to the right of the fan, and taped a simple thermometer at the back of the space?
Peter
Old 04-05-2016, 10:12 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ditto to above. We have the same model trailer as you and here is our quiet replacement fan.
However I can tell you propping the hatch lid open will cool the compartment better than fans.
Doug and Cheryl
Old 04-05-2016, 10:25 AM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I wonder if fridge would vent better if Airstream cut the upper vent higher up so there is more space between the condenser and the top of the box then install a curved insulated baffle that meets the top of the vent frame.
Kelvin
Old 04-05-2016, 11:38 AM   #10
AWCHIEF's Avatar
Images: 33
Peter, this one is not RS, that one burned up. Got this one from Amazon on the recommendation of several here. And yes I added the switch.
Noctua
4.9 out of 5 stars 145 Reviews
Noctua 120mm, 3 Speed Setting Anti-Stall Knobs DesiSSO2 Bearing Case Cooling Fan NF-S12A FLX
MICHAEL
Old 04-05-2016, 12:31 PM   #11
But this leaves the space open to insects IMO . . . as the doors have screening on their backsides . . .
Thanks Michael for the fan specs.
Old 04-05-2016, 12:49 PM   #12
dkottum's Avatar
The late models do have screens, earlier ones (our 2012) do not. The fridge compartment is sealed from the Airstream interior, the louvers are barely large enough for air flow, the screens may restrict it more. We prop open the doors for best compartment cooling.
Never had a bug problem in the compartment, none. But then most of our travel is in cooler months and dryer western climate.
Doug and Cheryl
Old 04-20-2016, 07:08 AM   #13
Thanks Doug, yes propping up the door works great. I also think that the fan sets up a vibration somewhere such that it sounds louder inside the trailer than it does standing right next to it outside. One poster on another thread actually suspended their fan on some nylon monofilament, which would prevent the vibration I think happens with a hard bolted/screwed connection. Maybe some acoustic dampeners to be added like the water pump feet? TBD
Thanks again,
Peter
Strange noises from the stereo? hshovic Audio, Video & TV 60 07-12-2009 08:45 PM
Voila! Strange noises from stereo fixed! hshovic Audio, Video & TV 7 02-07-2008 11:01 AM
Towing Question noises from hitch kdh0519 Hitches, Couplers & Balls 22 07-09-2007 09:58 PM
speaking of tranny noises... Chuck Tow Vehicles 12 05-02-2007 11:24 AM
Not trying to be noises ,But Angel73 Insurance & Claims 0 05-28-2006 11:21 PM
