Old 07-03-2013, 03:55 PM   #1
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Noise coming from behind panel board
I have a 2011 27' International. I just started experiencing a thing where there is a fairly significant high pitched noise coming from the panelboard area. Sounds like an electric fan that is going bad or needs oiling. Anybody experienced this? Any suggestions as its pretty much nonstop now and quite annoying. Thanks.
AirEPotter is offline   Reply With Quote
Old 07-04-2013, 12:07 AM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Not sure what you mean by "panelboard"...
Could it be a frig fan?
TB & Greg and Abbey Schnauzer
#3954
Old 07-04-2013, 05:12 AM   #3
LFC
Memphis , Tennessee
Sounds like your water pump might be running.
LFC is offline   Reply With Quote
Old 07-04-2013, 05:56 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
If the converter is behind the "panelboard", it could be the cooling fan.
Are you plugged in to shore power?
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-04-2013, 06:31 AM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Obscene title deleted
The converter gets dusty - get a vacuum cleaner and suck it out, especially around the fan. If that doesn't fix the problem, your fan motor may be going bad and the fan may need to be replaced.
Paula
Old 07-05-2013, 09:25 AM   #6
AirEPotter's Avatar
Lubbock , Texas
Converter is behind the panelboard. I am thinking its a cooling fan. It only makes the noise when I am connected to shore power.
Old 07-07-2013, 11:28 AM   #7
LFC
Memphis , Tennessee
That's the only time the converter is running.
Old 07-07-2013, 03:22 PM   #8
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
There is a small fan that is part of the converter. The speed is supposed to vary according to the temperature of the converter. Normally it should be barely audible but as it warms up in there, the speed picks up and a noticeable fan noise will be heard. The bearing in the fan is not designed for longevity but from the age of the trailer in your profile, it sounds like it may be prematurely failing if it sounds like a bearing noise. As previously mentioned, try vacuuming out the converter to remove a possible layer of dust that may be retaining heat and making the fan speed up. Canned or compressed air may also be helpful to blow it out.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 07-16-2013, 05:16 AM   #9
n/a , n/a
Rivet
Thanks for that topic, I find it very interesting.
sex filmy
DrZboczek is offline   Reply With Quote
