Old 04-04-2013, 04:07 PM   #1
2008 31' Classic
Sweet Valley , Pennsylvania
No water at bath sink
Hi all
Just putting water to the system. I get water at the kitchen sink and bath shower but no hot or cold at the bath sink. Classic Limited 2008 any ideas would be greatly appreciated. Thanks Jim
TROPHYJIM2 is offline   Reply With Quote
Old 04-04-2013, 04:11 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sometimes when you first put water onboard you can kick up sediment in the hot water heater. That can clog the screen on the bathroom sink faucet, as it is the close to the heater. Try removing the screen and check it. While the screen is off see if you have water at the sink.
2004 Excursion 4x4
Old 04-04-2013, 04:39 PM   #3
2008 31' Classic
That's it thanks Howie!!!!!
Old 02-28-2018, 07:19 PM   #4
Highlands Ranch , Colorado
Homie, thanks for the tip. Here it is 5 years later. I just had the same problem, and fixed it with the same solution.
mhenehan is offline   Reply With Quote
