04-28-2015, 08:23 PM
Looking 4 new adventures
1996 28' Excella
Englewood
, Ohio
No water
Just bought a 1996 28' Excella Widebody and I have no water flow either via a city water hookup or via pump and the water tank? i need help!
04-28-2015, 08:32 PM
Common Sense
I have had the aireator/screens at the output of the faucets get stopped up with crud that came loose from the interior of the water heater and prevented water flow. You might check those aireator/screens.
You did not say, but do you have no water at any of the faucets, or the shower, or the toilet?
Regards,
Steve
04-28-2015, 09:05 PM
1999 34' Excella
Hillsboro
From your registered location, I wonder if you have the valves set 'off',...as in 'winter mode'... do you have the manual? You can download from the Mothership...
Peace and Blessings..
Channing
WBCCI# 30676
04-29-2015, 07:16 AM
1996 28' Excella
Englewood
, Ohio
Has water....now no water!
Just bought a 1996 28' Excella Widebody. Initially I had water flow when dewinterizing the unit then about half way thru the process no water flow either via a city water hookup or via pump and the water tank? I need help!
04-29-2015, 07:36 AM
1972 31' Sovereign
Lexington
Do you have water flow at the tub/shower? What about the toilet? If you have water at those two, but not the sinks, then the aerators in the faucets got clogged. Pretty common while de-winterizing.
Chris
04-29-2015, 07:41 AM
1996 28' Excella
Englewood
, Ohio
I have no water flow at any location. I had water flow when rinsing out the faucets and toilet, then all water flow stopped.
Gary , Linda & Jasper 🐶 Peck, Englewood, Ohio
1996 28' Excella, 2015 GMC Sierra 2500HD Duramax
Enjoying our retirement and AirStreaming at least four to six months a year!
04-29-2015, 07:54 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
You're still not providing a whole lot of information that readers can use to remotely diagnose the problem.
First, if you have municipal water connected, your pump isn't going to work even if you switch it on. The city water pressure prevents the pump's pressure switch from activating the pump. So let's not worry about the pump right now. Turn it off and work on municipal water only for now.
Second, have you checked for leaks? If water is coming in but not going to the faucets, then it has to be going somewhere. Check your low point drains and make sure they're actually closed. Then start opening cabinets and tracing your water lines beginning at the municipal water intake to see if you can find a leak. Keep at least one faucet cracked open to allow water to flow if it can. Note that a leak is more likely than a clog, and if none of the water gets to the faucets, then a complete break in the line is more likely than a small leak.
Once you've determined if there's any leaks, report back to us and tell us what you found, and we'll figure out where to go from there.
04-29-2015, 08:02 AM
1972 31' Sovereign
Lexington
Pull the low drains and see if you have water in the water lines. Check for water flow again from both the pump and the city water inlet with the low point drains open. If you have no water flow out of the low point drains, then as odd as it sounds, you might have two problems. One is the inlet filter on the water pump. The other one is the check valve on the city water inlet.
On your trailer, is there an inline water filter? I know some airstreams have one, but I don't know what years do and do not. If you have an inline filter, it's probably clogged. I would check that first if you have one.
Another test would be to hook up a garden hose to one of the faucets. You'll need an adapter to do that. Then you can run water into that faucet and see if you get water out of the other faucets.
04-29-2015, 08:23 AM
Common Sense
Based on that, I would wager your aireator/screens are clogged. I've had it happen several times when de-winterizing.
Regards,
Steve
04-29-2015, 08:28 AM
From All Over
Does the toilet even have an aerator/screen?
04-29-2015, 08:30 AM
Common Sense
No, but at this point I'm doubting the totality of the info we are getting.
Regards,
Steve
04-29-2015, 08:38 AM
From All Over
As am I. It's a lot harder to talk someone through the troubleshooting process so that he can find the problem than it is to just offer solutions once the OP has done his own troubleshooting and identified the problem.
The OP has not told us the problem, he only told us a symptom of the problem. Unless we can help him find the problem first, I very much doubt that us tossing solutions at him will help very much.
04-29-2015, 08:56 AM
1996 28' Excella
Englewood
, Ohio
All aerators have been removed and there is no aerator or screen in the toilet. I have told you all that has happened!
04-29-2015, 09:11 AM
Common Sense
At this point if it were just the pump output, or just the city water not working, it would give us a clue, but since you have no water from either, and the aerators are not plugged, I just don't know.
The water from the pump comes into the system at a different place than the water from the city hookup, so a plugged line is unlikely.
You actually might want to call Airstream and talk with them. I have found them very helpful in the past.
Regards,
Steve
04-29-2015, 09:19 AM
From All Over
Have you checked for leaks? If so did you find any? Have you checked the low point drains? Were they closed? Aside from removing the aerators, have you done anything else we suggested to troubleshoot the problem? There's no need to panic. Troubleshooting a problem consists of trying everything until you discover the source of the problem, and it takes patience.
Here's another option for troubleshooting. Disconnect the hose from the municipal water inlet. Attach a blowout plug. Open a faucet, doesn't matter which one. Have someone inside watching the faucet. Blow compressed air into the system just like if you were winterizing. Does air come out the faucet?
04-29-2015, 09:28 AM
I'm In
, Kentucky
J Initially I had water flow when dewinterizing the unit
When you de-winterized, were you using city water or the pump/FW tank when you had the initial water flow?
Was the water coming out of the AS faucets and it stopped or were the faucets closed and you opened one and no water came out?
Have you disconnected the hose from the AS city water inlet? (make sure you aren't connected to the black water flush inlet; common error.) If you have disconnected the water from the AS and the water pump is "on" does the water pump come on when you open a spigot in the trailer? (I'm assuming you have the store/use switch set to use or you have external 110vac power connected to power the AS.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
04-29-2015, 07:28 PM
1996 28' Excella
Englewood
, Ohio
Here's the latest. Tonight I tried using the water in the holding tank (on the curbside of the unit) and the pump would run for 15 seconds then turn off when pressure was adequate. No water came out of the kitchen sink, the shower, the toilet and the bathroom sink. I then connected to city water (street side of the unit) and I had water in the bathroom, both sink and toilet, the water heater filled (street side also) but I had no water from any curbside outlet (shower and kitchen sink). Is there a valve that separates the curbside piping from the street side piping?
04-29-2015, 07:36 PM
2002 30' Classic S/O
Fleming Island
A little terminology. The water tank is just that, the water tank. There are one or two holding tanks - one for the toilet (black tank) and another for the sinks and shower (gray water). The potable water tank (curbside) is not called a "holding tank".
Al
04-29-2015, 10:45 PM
I'm In
, Kentucky
Definitely seems like a blockage or a closed valve. Is there any way you can contact the previous owner? If not, try contacting Airstream support. They usually answer in a day or less.
-Rich
Rich & Yvonne
05-06-2015, 11:47 AM
1996 28' Excella
Englewood
, Ohio
The latest. I have running water in the streetside bathroom by city water and pumped water. The pump works fine. I have no water flow on the curbside kitchen sink and shower. Is there any type of shutoff that would interrupt the flow after the pump?
