Old 04-29-2015, 09:19 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by garympeck View Post
All aerators have been removed and there is no aerator or screen in the toilet. I have told you all that has happened!
Have you checked for leaks? If so did you find any? Have you checked the low point drains? Were they closed? Aside from removing the aerators, have you done anything else we suggested to troubleshoot the problem? There's no need to panic. Troubleshooting a problem consists of trying everything until you discover the source of the problem, and it takes patience.
Here's another option for troubleshooting. Disconnect the hose from the municipal water inlet. Attach a blowout plug. Open a faucet, doesn't matter which one. Have someone inside watching the faucet. Blow compressed air into the system just like if you were winterizing. Does air come out the faucet?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-29-2015, 09:28 AM   #16
richw46's Avatar
Lexington , Kentucky
J Initially I had water flow when dewinterizing the unit
When you de-winterized, were you using city water or the pump/FW tank when you had the initial water flow?
about half way thru the process no water flow
Was the water coming out of the AS faucets and it stopped or were the faucets closed and you opened one and no water came out?
no water flow either via a city water hookup or via pump and the water tank?
Have you disconnected the hose from the AS city water inlet? (make sure you aren't connected to the black water flush inlet; common error.) If you have disconnected the water from the AS and the water pump is "on" does the water pump come on when you open a spigot in the trailer? (I'm assuming you have the store/use switch set to use or you have external 110vac power connected to power the AS.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-29-2015, 07:28 PM   #17
Looking 4 new adventures
garympeck's Avatar
1996 28' Excella
Apache Junction , Arizona
Here's the latest. Tonight I tried using the water in the holding tank (on the curbside of the unit) and the pump would run for 15 seconds then turn off when pressure was adequate. No water came out of the kitchen sink, the shower, the toilet and the bathroom sink. I then connected to city water (street side of the unit) and I had water in the bathroom, both sink and toilet, the water heater filled (street side also) but I had no water from any curbside outlet (shower and kitchen sink). Is there a valve that separates the curbside piping from the street side piping?
Gary ,Linda & Jasper 🐶 Peck, Apache Junction, Arizona
1996 28' Excella, 2015 GMC Sierra 2500HD Duramax
Enjoying our retirement and AirStreaming at least four months a year!
garympeck is offline   Reply With Quote
Old 04-29-2015, 07:36 PM   #18
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
A little terminology. The water tank is just that, the water tank. There are one or two holding tanks - one for the toilet (black tank) and another for the sinks and shower (gray water). The potable water tank (curbside) is not called a "holding tank".
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 04-29-2015, 10:45 PM   #19
richw46's Avatar
Definitely seems like a blockage or a closed valve. Is there any way you can contact the previous owner? If not, try contacting Airstream support. They usually answer in a day or less.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 05-06-2015, 11:47 AM   #20
garympeck's Avatar
1996 28' Excella
The latest. I have running water in the streetside bathroom by city water and pumped water. The pump works fine. I have no water flow on the curbside kitchen sink and shower. Is there any type of shutoff that would interrupt the flow after the pump?
Old 05-06-2015, 12:52 PM   #21
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
All our trailers get "re-designed" by previous owners who think they have a better idea. Some of these mods are skillfully done and wonderful, and others not so much...
I will assume at this point in the discussion that you've eliminated large leaks and open drain valves. You'd have noticed the water by now.
Can you trace the water lines out visually to see if someone has installed a valve, kinked a line, or some such? Water lines are installed above the floor in an Airstream, usually at the very edge of the floor next to the outer wall. It takes a lot of crawling around and looking into remote corners with a flashlight, but it can be done.
It is also possible for crud to precipitate out of very hard water and accumulate inside a water pipe. Used to see that in houses when I lived in hard water country.
Good luck finding the problem.
Old 05-06-2015, 02:00 PM   #22
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
That sure sounds like a valve or two are shut off.....somewhere !
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-06-2015, 05:00 PM   #23
Gainesville , Florida
I've heard it called the freshwater holding tank because that is what it is. Jim
Old 05-06-2015, 06:52 PM   #24
garympeck's Avatar
1996 28' Excella
Here is the latest...city water works on streetside but not on curbside, same for water from water holding tank. I have hot water in bathroom sink but no water in kitchen sink or shower. Is there a shut off valve that I haven't located?
Old 05-06-2015, 07:21 PM   #25
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
That would seem to be what most of us are betting on. As stated above it is not uncommon for a previous owner to have a "better" idea and install additional valves etc. That leaves it in your court to figure out what he was thinking, or not.
Gearheart is offline   Reply With Quote
Old 05-06-2015, 07:47 PM   #26
SteveH's Avatar
Common Sense , Texas
What did you do to get the water flowing in the bathroom sink?
Regards,
Steve
Old 05-12-2015, 09:20 AM   #27
garympeck's Avatar
1996 28' Excella
To all who mentioned aerators you were very close. The problems were actually totally clogged kitchen faucet/sprayer and shower sprayer. After replacing both I am in business. Thanks for all the ideas and comments.
Old 05-12-2015, 12:34 PM   #28
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Congrats!!!
Channing
WBCCI# 30676
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
