Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-18-2015, 10:36 AM   #1
2004 28' International CCD
Cocoa , Florida
No trailer brakes
Hello Streamers!!!
I have no trailer brakes on my 04 international, I found my plug on the tow V (2000 Navigator) was burned. I replaced it and still no brakes. I do have lights and signals. Mechanic tested power to brake control on dashboard and it had 13 volts to the box. I figured when the plug shorted, it shorted out the controller also. So I replaced that, STILL NO BRAKES. The new controller has a LED readout and it's showing that it's NOT connected.... Any ideas b-4 I pay the rent at camping world????
Hope you all have a GREAT weekend!!
Be careful
Bhkh226 is offline   Reply With Quote
Old 06-18-2015, 10:45 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
If you introduce voltage to the brake circuit (say with the breakaway switch) do the brake magnets swing a compass needle? It's possible that the short that burned the original 7-pin connector was in the brake wiring between the umbilical and the brakes (or perhaps in the umbilical itself, have you metered that for proper insulation and continuity?)
It's most likely an electrical troubleshooting exercise.
— David
DKB_SATX is online now   Reply With Quote
Old 06-18-2015, 11:35 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like you have an Open somewhere in the circuit.
First test for voltage at the female connector on the TV. If you have voltage there connect the umbilical cord and test for voltage at the trailer end of the umbilical cord, where it enters the trailer. If no voltage there the open is in the cord. If voltage there the line going back to the brakes is likely open.
2004 Excursion 4x4
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
