Old 09-15-2013, 03:32 PM   #1
2007 25' Safari FB SE
Bemus Point , New York
No power in Safari bathroom
Any ideas for what could cause a loss of electrical power to the bath lights and water heater in a 25' safari FB? Fuse is good and bulbs work in other lights. All other power throughout is ok.
jetjocky is offline   Reply With Quote
Old 09-15-2013, 04:17 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
In my 2007 20' the bathroom lights are controlled by a wall switch, but there is also a push button on each light fixture. They all have to be on for the lights to work.
As far as the water heater goes, do you mean the light on the rocker switch fir the heater? If so, that initially lights up but goes off when the heater fires up and stays off unless there is a fault.
Old 09-15-2013, 04:36 PM   #3
Lothlorian's Avatar
Loganville , Georgia
I have had this problem before. If you do not have a solid connection to the fuse it will kick out. Take the wire out for the bathroom and make sure it is not corroded and the same for where it is screwed in. Then screw it back into the fuse panel.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
