Old 10-24-2016, 02:16 PM   #1
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
No heat from furnace
The furnace did work when I checked it a few months ago. Right now, the sequence of events is:
- switch on using the spst switch on side of thermostat
- after about 30 seconds, the fan comes on
- fan continues to run, but there is no evidence of ignition, even after several minutes.
I checked the igniter, and the gap is not burned (compared with a spare I have), and there is sufficient propane (gauge on the regulator shows green and my blue-flame heater works).
I'm not sure exactly where the sail switch is, but I suspect that it may be the problem; or it could be the module board. Given that the temperature is dropping down below freezing, I'd like to get the furnace working ASAP - I head south in 2 weeks.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 10-31-2016, 06:34 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
It was a bent bracket for the sail switch.
VE3JDZ
AIR 12148
WBCCI 8080
Old 10-31-2016, 06:37 PM   #3
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Thumbs up
Thanks for letting us know what the problem was !
1972 Ambassador Itn'l 29'.Custom Interior FOR SALE.
1978 Avion 34W
Airline is offline   Reply With Quote
« Bike rack | Top | Duct Work »
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
