Old 06-10-2015, 08:20 PM   #1
Champaign , Illinois
Newbie with a '68 Overlander
I have a 1968 overlander that I have just started to gut and I'm looking for any and all advice. So far I have found water damage around the front window, the fixed windows and the door. My goal is to fix the leaks and go from there.
Cmcc_7 is offline   Reply With Quote
Old 06-10-2015, 08:30 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Welcome to the forums and congrats on the 68. I'm a just a little biased but I think 68 was a great year. Feel free to PM me anytime if you run into a problem or have a question about anything. I had several mentors when I restored mine and I could not have done it without them.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-10-2015, 09:46 PM   #3
Thx twind. I already have a question for you...where should I buy window gaskets from? Also should I be looking for the D shape gasket or the solid square type?
Old 06-11-2015, 01:21 PM   #4
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
For the water comoing in around your door look at Vintage Trailer Supply or Inland RV for new door gaskets and most importantly, those bolts (looks like phillips screwheads) on your cast aluminum door frame go through the sub floor. Take the time to seal those up. I put new bolts in with sitkaflex221 to seal em up. Also leaks that caused the damage can come from failing rivets, leaking awning bracket or awning rail or the roof vent/fan
thesignlady is offline   Reply With Quote
Newbie help request from Newbie southsaglejim Plumbing - Systems & Fixtures 18 09-10-2014 07:39 PM
1957 Airtream Overlander Newbie kim McCumber Member Introductions 7 09-29-2008 07:47 PM
Price Question from a Newbie *1969 Overlander* lubbockgolf Trailer Values 3 04-24-2007 09:05 PM
Newbie - 26' Overlander GreatPumpkin Member Introductions 7 04-13-2006 06:44 AM
Newbie Overlander Towing Questions 63overlander 1960 - 1964 Overlander 17 05-20-2005 10:44 PM
