Newbie here with a “did I mess up a lot or a little” question:
I forgot to unlatch the stove exhaust vent outside and I cooked dinner and breakfast before I remembered😳! I unlatched it and the fan seems fine. Is there anything else I should check? Does the fan turn itself off if it overheats?
You probably did no harm. It is just a fan that is trying to move air that has no place to move to. If this could instantly ruin a fan motor, then all of those fan-based inflators that blow up air mattresses and childrens' bouncy houses would be failing constantly.
If you use the "custom" vent door retainer, the fan will run quieter and move more air. If you forget it's also slipstream removable and easily replaced. 👍
