Old 09-02-2015, 07:48 PM   #1
minnstream's Avatar
1972 29' Ambassador
golden valley , Minnesota
Newbie? not really
Hi forum members,
This is my first new thread, although my wife Laurie and I have had our 1972 ambassador 28' trailer for then years now. I want to thank all the posters for sharing their precious information and experience. It has kept us from making mistakes during our recent renovation of the rear bath. We needed to replace about 3' of the subfloor due to rot. Thankfully the frame was only minimally rusted. The black water carrier for the tank was toast and had to be replaced. I decided to remove the heater vent in the bathroom and lower the tub/shower pan to the subfloor. I am 6'3" and needed the extra headroom. We also removed the shower door and I devised a way to mount a rod to the curved wall above the sink so we could use a curtain. The shower trap now has a removable drain plug that projects through the belly pan for winterization. All plumbing is now pex also.
One question I have been wanting to ask for a long time is this: Has anyone considered using spray foam to insulate a trailer during a complete gut remodel? It seems like this would be helpful structurally as well as helping to eliminate the critter issues that come with an older trailer. I would also think that the trailer would be warmer (or cooler) due to increased R-value and lower air infiltration.
I also wanted to mention that I am two years away from retirement and Laurie and I are planning to upgrade to a newer trailer and seriously hit the road. We are liking the excellas with the rear bedroom. I'm hoping that the mid bath will give me a little more room. Does that seem reasonable to expect?
Mike
Mike and Laurie
minnstream is offline   Reply With Quote
Old 09-02-2015, 08:52 PM   #2
Mission , Texas
Newbie? not really
There is are a lot of different opinions about spray foam and a few threads as well as remodel blogs. Do a Google search for Airstream Spray Foam.
If ours ever needs to be gutted, the insulation will be spray foam.
nrgtrakr is offline   Reply With Quote
Old 09-02-2015, 09:32 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Avion used a spray foam in their trailers. The Cayo brothers are still active providing parts and service for Avions. Those who've gotten into the guts say the foam is like new, so that would be my source for the best product to use.
Paula
Oh and WELCOME to the Forums
Old 09-02-2015, 09:42 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Do they "spray", allow to cure then trim the foam level?
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-02-2015, 09:54 PM   #5
Naddy's Avatar
1957 26' Overlander
Moscow , Idaho
I was also thinking about using foam for my 1957 Overlander. While researching the topic, I came across this blog entry by Hofmann Architecture, who - arguably - do pretty nice renovation work.
https://hofarc.com/7-advantages-to-s...am-insulation/
That one made me thinking
Mark
Naddy is offline   Reply With Quote
Old 09-03-2015, 07:40 AM   #6
Mission , Texas
One spray foam job documented in photos that I saw was spray every other section, carve it down flush (like doing a house), then come back and do the rest.
Old 09-03-2015, 04:08 PM   #7
minnstream's Avatar
1972 29' Ambassador
I checked out some earlier threads on insulation, lots of information. At work we use spray foam for remodeling houses. One technique that the professionals use is to flash coat with a very thin layer of foam and when that is cured go over it with more layers. I bet this would control the heat and warping of the aluminum. The foam doesn't cure properly if it is applied too heavy. There is a lot of science involved in properly applying the foam.
Mike and Laurie
Old 09-03-2015, 04:29 PM   #8
ericpeltier's Avatar
Superior , Colorado
I am gutting a 1972ish Streamline that came from the factory with spray foam. I do think it insulates really well, but I have a downside to relate. I think it makes it very hard to find leaks. I wish, through the course of this remodel, that I could pull out the insulation easily and do some leak tests. It's VERY hard to get the spray-insulation out of the spaces in the frame.
ericpeltier is offline   Reply With Quote
Old 09-03-2015, 08:18 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Where do you get the spray equip and supplies? Do you expect someone me to do this for you from an "installer"?
Channing
WBCCI# 30676
Old 09-03-2015, 08:53 PM   #10
minnstream's Avatar
1972 29' Ambassador
Two part do it yourself foam kits are available at big box stores. You get 600 sqft at 1" thickness for about $400.00. I couldn't find if it is open or closed cell. I remember that the specifications for spraying varies according to the chemicals and delivery system involved. It's very technical. Better left to the pros.
Mike and Laurie
Really, really new Bambi! Pahaska Off Topic Forum 3 05-12-2009 08:20 AM
Really, really new!! Globeville Member Introductions 6 08-20-2007 03:33 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
Really really great site and Airstream FrankR On The Road... 5 07-14-2002 02:10 PM
