Old 05-30-2019, 01:10 PM   #1
1999 19' Bambi
Minneapolis , MN
Newbie+Awning replacement=Confoundation.
Hello All!
I've been perusing the ASForums for a couple years, mostly looking at ads, dreaming,yearning and then BAM! The Universe presented a 1999 Bambi (19ft) that had my name on the bellypan. Found online from a local RV dealer, she's in my affordability range, stills goes down the road, and I can take camping As-Is (mostly). And my credit union gave me a loan, go figure!!
Attachment 342093
As you can see, as I did when I looked at her, there is no awning. Because I had been lurking around and reading all y'alls adventures in repairs, I hoped that replacing the fabric could be done with some looking at the binder of manuals that came with her, following links/YouTube suggestions, etc. without resorting to replacing the whole shebang with a spankin' new ZipDee (shook-DING $$). I also need a lower bracket, as the repair that was made by prior owner will not hold. In addition, I'd like to add the snazzy aluminum protective covers that the roller fits under to prevent the rot that made the original awning fall apart in the first place, IF it's possible. HOWEVER, I don't even know what A&E Dometic model I have; my booklet just says "Curved Square 1" Hardware" on the front- no numbers. I did download the service manual from a link on a different ASForums thread which had all the Bambi parts listed, but there was no model number for interwebs searching.
I have perused the Sunbrella patterns, I have a seamstress with the required HD sewing machine, my Husfriend is an ex-NWA aviation (as well as automotive) mechanic, and is pretty much on board with tools/talent for installation. But getting the info pertaining to model, parts, and possibility of actually recreating a working awning with the existing A&E is confounding me. I am the shopper, the finder, the refreshments and parts runner. Before we take the awning assembly off the Bambi, I'd like to know what all is possible. Help me Mr. Wizard!
ChopstikDee is offline   Reply With Quote
Old 05-31-2019, 08:45 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Some of the parts are the same across a number of models. More photos of the damage would be helpful. To get you started here are a few parts on Dyers website to compare to your damaged parts.
https://www.dyersonline.com/dometic-...-assembly.html
https://www.dyersonline.com/dometic-...ement-kit.html
https://www.dyersonline.com/dometic-...d-bracket.html
https://www.dyersonline.com/dometic-...rvice-kit.html
https://www.carefreeofcolorado.com/r...rotection.html
I'm not sure if the alumigard from carefree will install with dometic/A&E awning parts. Hopefully someone else can lead you in the right direction on that topic.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 06-05-2019, 12:17 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
It may be worthwhile calling Zip Dee - 800-338-2378 - and speaking with Randy. They can make up the entire awning with all the hardware and ship it to you for you to install.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
