Old 04-09-2012, 01:47 PM   #1
1978 Argosy 27
Hoover , Alabama
Newbee water pump
I have had two other rv but always used them as park models...never considering a water pump or knowing its purpose.
So in the argosy reno I wonder if I need a water pump in the unit?
What is the purpose of the pump? I thought it would be used to pump water from the water tank, which we have pulled out of the unit.
Charles
cford is offline   Reply With Quote
Old 04-09-2012, 02:04 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The water pump is used to pump water from the tank to the fixtures. If you don't have a tank you don't need a pump, however if away from hook ups you will be operating out of jugs..
You may have to block the lines that would have gone to the pump to have a watertight system when hooked up. The pump itself usually has a check valve
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-09-2012, 02:06 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The purpose of the water pump is to pump water from the on board fresh water tank to supply the rest of the trailer with fresh water when you are not hooked up to city water.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-09-2012, 02:18 PM   #4
1978 Argosy 27
Hoover , Alabama
Thanks for the insight.
I asked a dealer and they indicated it was required hooked to city water or not. I thought it was odd. I knew I needed to ask you guys, the real pros.
Old 04-09-2012, 02:40 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Not all campgrounds have facilities, in which case you will want a fresh water tank and a pump.
