Old 05-21-2016, 11:43 AM   #1
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
New to me battery type
I have just run across a new to me AGM battery type. It is called a carbon foam battery, and if claims prove out could be a big improvement. They are claimed to have low sulfation, and you can run them down to 20% or even 0% power without losing capacity. Here is a link to some info.
I have no connection with this whatsoever. Just wanted to know if any of you in aluminum land have had any experience with them.
http://www.bruceschwab.com/advanced-...asis-group-31/
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 05-29-2016, 10:00 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Try looking at this article:
http://www.practical-sailor.com/blog...e-11694-1.html
What concerns me is that the manufactures tests design may hide the sulfation problem due to not waiting long enough between discharge cycles so the sulfate does not have enough time to harden. You can obtain the same results with a good charger on a flooded battery.
I believe that all lead/sulfuric acid battery operate with the same chemistry and it is the chemistry that locks you into the sulfate issue, just part of the battery charge/discharge cycle (Pb + H2SO4 -> PbSO4 + H2O).
sgschwend is offline   Reply With Quote
Old 05-29-2016, 11:01 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Have you read their warranty?
It looks like they have included every possible way to get out of covering the battery by things like operating temperatures, type of cleaners used on the battery casing, decrease in charge retention capacity before the warranty period expires (what's with that???) etc.
I would be very suspicious until I see more test data from actual use, not the manufacturer. As stated above, they do not specify their waiting times between recharging, which is key to preventing sulfating in any lead based battery system.
Be careful out there!!!
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Battery type in my 2007 Interstate... new and confused! patrickdylan Batteries, Univolts, Converters & Inverters 9 07-12-2009 08:16 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
What type of battery should we get? Anna Electrical - Systems, Generators, Batteries & Solar 3 11-26-2002 10:23 AM
