Old 02-16-2010, 12:36 PM   #1
biopig's Avatar
1964 26' Overlander
baldwin city , Kansas
new owner with questions
I'm a new owner of a 64 overlander. Towed home 500 miles last fall, no problems. Very happy with trailer, of course there's a few things I would like to improve.
Name:	Clay Motion Madness!!! 003 (Medium) (Small).jpg
I also have a few questions for the overlander experts. 1) How is the black water tank held in place and what is it made out of? Mine appears to be fiberglass. 2) Did these trailers come with any 12v fuses? I can't seem to find any. 3) Do any you have the odd window frames? If so where can I find new glass to frame seals? Are there any suppliers for the cranks and extension arms?
Name:	Clay Motion Madness!!! 008 (Small).jpg
Thanks for all your help
biopig is offline   Reply With Quote
Old 02-16-2010, 03:10 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I`ll bump you back up for the experts to answer your ?.Dave
easyride is offline   Reply With Quote
Old 02-16-2010, 03:14 PM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Fuses are probably in the Univolt in your trunk. Behind a wing nut I think?
All window material can be found at Inland RV or other vendors found on this site.
Can't help you with the tank.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 02-16-2010, 03:20 PM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Vintage Trailer Supply is a good source of parts, give them a yell.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-16-2010, 03:23 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings biopig!
Welcome to the Forums and the world of '64 Overlander ownership!
The blackwater tank is, indeed fiberglass and is mounted below the toilet between the frame rails. There is a galvanized steel box that it rides in that is held to the frame with steel strapping (at least that was the case with my '64 Overlander).
The 12-volt fuses were monted behind an access panel on the old Univolt found in the streetside corner of the One-Stop-Service-Compartment (rear trunk). It has been a few years since my original Univolt was replaced, but I seem to remember that it was a rather large dark green box behind the battery/shorepower switch with the red reversed polarity light. If your original Univolt has been replaced -- the first place to look would be the replacement power converter -- to see if it has fuses behind a panel. Should that prove futile, you may be looking for a needle in a haystack.
Unless your coach's windows have been replaced, or were a custom order feature, they should be a standard Hehr model utilized in virtually all '64 Airstreams. The new replacement weather seals have a somewhat different appearance when compared to the original factory items -- they do seem to seal better, however. There are at least two sources for the necessary seals and gaskets - - - Vintage Trailer Supply and Inland RV.
The window crank gearboxes can be a bit more difficult to locate, although availability seems to be better today than it was nearly eight years ago when much of my coach's refurbishment was completed. You may be able to find these gearboxes at a local shop that supplies parts for older mobile homes (often found in larger college communities where I live). You can also check with Vintage Trailer Supply and Inland RV.
Good luck with your Overlander!
Kevin
Kevin D. Allen
AIR #827
Old 02-16-2010, 03:36 PM   #6
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Welcome to the '64 club! You will want to read this thread here, all about the Mystery '64 windows that I have, and it looks like you too. The good news is some of the parts you are looking for are available.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 02-16-2010, 03:42 PM   #7
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
When you read through the thread I referenced, you will see that Frank of Franks' Trailer Works may have some windows for your '64 available. I also covered these windows on my blog as well, which you can find by following my signature below.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 02-16-2010, 04:49 PM   #8
biopig's Avatar
1964 26' Overlander
Thanks for the fast response everybody. My windows are all the odd style, The PO used screen clips on the outside to hold the windows shut. Any idea's on the glass to frame gasket. VTS can get it but you have to order a complete roll. Thanks again, Silva
Old 02-16-2010, 06:51 PM   #9
biopig's Avatar
1964 26' Overlander
Kevin, thanks for all the good info. When it worms up here I'll take a closer look for the uni-volt. The reason I asked about the black tank is mine looks like its just resting on the galvanized sheet metal skin. Doesn't look like theirs anything holding it in place. Thanks
86 motorhome new owner questions comotionman Classic Motorhomes 5 11-27-2009 05:33 PM
New Owner Questions Hol & Lols 2005 and newer - Bambi all models 49 08-10-2006 08:47 PM
Questions from a new AS owner...... Tikiman General Repair Forum 4 07-20-2005 11:14 AM
New AS owner with questions Zmod Our Community 11 12-03-2003 06:25 PM
Questions from a new A/S owner. Help. bluvalley Hitches, Couplers & Balls 6 10-30-2003 11:58 PM
