Old 08-31-2012, 09:36 PM   #1
Inverness , California
New Flying Scott Shower Door Slider problem - Help welcom
I have only used the shower several times in my 2012 Flying Scott. All seemed fine - then the upper slider fell off and I cannot get it secured back in place - when I get one end positioned, then put the cap on the other end, it will not snap into a secure held position -- won't fit into the secure position (snapped behind screw).
The door also will not latch.
I think it may have been installed incorrectly at the dealership.
The door handle is on the exterior of the shower door. I assume that is correct, but I don't know what the slider would have fallen off.
I am a bit dissapointed by some of the tacky quality in an otherwise great little unit.
KayMc is offline   Reply With Quote
Old 08-31-2012, 09:37 PM   #2
Gainesville , Florida
Flying Scott? Jim
Old 08-31-2012, 11:12 PM   #3
19 Foot Flying Cloud 2012 Shower Door Slider Problem
I have only used the shower several times in my 2012 19 ft Flying Cloud. All seemed fine - then the upper slider fell off and I cannot get it secured back in place - when I get one end positioned, then put the cap on the other end, it will not snap into a secure held position -- won't fit into the secure position (snapped behind screw).
Old 09-01-2012, 11:08 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
These tend to loosen. Mine did and, yes, the door shift kept the latch from operating easily. I tightened it once and it has held ever since.
Yours fell apart? Any way to take a pic of what you have?
How to add photos to a post
5 meter Langford Nahanni
