Old 12-11-2017, 08:30 AM   #1
1972 23' Safari
Middletown , Rhode Island
new fan install wire question - 72 safari
I have a question on which wires to connect my maxxair fan to in the front. I'm in the process of replacing my 45 year old original fan. When I started to remove my old unit I had to cut 2 red wires that were connected to the fan. I think these wires powered the fan motor when the skylight was opened, do I just cap off these wires and connect my new wires from the maxxair fan to the wires that powered my ceiling lights that were there? Thanks.
Mx468 is offline   Reply With Quote
Old 12-11-2017, 08:44 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you only ever want the fan on when the light is on that will work. If you want to control the fan separately you have to find a 12 volt source.
Not sure what your are saying when you say you cut 2 wires. The older roof fans were wired with a 12 volt source going to a switch in the vent cover. When the vent was opened the fan would come on some units had a switch second switch to be able to turn the fan off while the vent was open.
Test the red wires for voltage and wire the new fan to that assuming the new fan has some switching built into it. This will allow the new fan and or it's switch to control the fan.
As for the second red wire if you do not connect it I would assume some thing may no longer work. If you find something not working then you can decide if you want to connect it.
2004 Excursion 4x4
Old 12-11-2017, 08:19 PM   #3
1972 23' Safari
Here are some pics...
After looking at the wires again I think what was throwing me off was the wire attached to the switch, so when the skylight is opened it makes the metal on metal contact to complete the circuit which in turn makes the fan run, so I just pull off the spade on the switch and connect it directly to my negative/ground wire on my new fan and positive wire to positive, and that should work, right?
ID:	300772   Click image for larger version
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Fantastic Fan install question Sovereign86 Roof Vents, Skylights & Fans 6 02-17-2009 07:16 AM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
