Old 06-23-2015, 06:24 PM   #1
2015 28' Flying Cloud
Melbourne Beach , Florida
New Ducted Air Conditioning
I am considering buying a new 2015, 28 foot with directional ducted air. I looked at one with the ducting and it looks beautiful and sounds better than current method to disperse cold air.
My concern is that a lot of cold will be lost in the distribution system and the result will be inadequate cooling with current BTU recommendations.
I was in Texas last week at 99F in a sunny park spot and the 15,000BTU system on my 25 Flying Cloud just did not cool well. If I was to lose any cooling from current system it would be really bad inside on a sunny day.
Has anyone with a ducted A/C experienced poor A/C performance?
Thanks.
Kingsmen 33 is offline   Reply With Quote
Old 06-23-2015, 07:04 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Thanks.
I think you have answered your own question. If the 25' trailer with the 15K air conditioner was marginal in Texas, and assuming it is functioning properly, you can't expect a larger trailer to be adequate for you with the same BTU rating. Ducting won't help you make that air colder and if it creates any additional back pressure into the air flow, that loss will make a marginal situation all the worse. Running air through ducting creates friction and because of the ducts and outlet vents, its inevitable that you will get a some loss of efficiency. How much depends upon how well Airstream sized the ductwork and how many curves that ductwork has in it. Air resistance from the vents themselves can affect outflow.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-24-2015, 08:02 AM   #3
2016 30' Classic
Erie , Colorado
Dual air conditioners on a 28. On my 2015 Classic running one unit is good into the 80's. pass 90 and better to run both. At 120 in Las Vegas or Phoenix with no shade not sure anything will keep up other than being in a casino
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Ducted Air Conditioning; Sound Level Numbers mefly2 Airstream Trailer Forums 29 07-13-2016 09:24 PM
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
