Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 11-22-2005, 10:59 PM   #1
Deano69LY
Profile:  1969 27' Overlander
Colorado Springs , Colorado
new carpet to a almost full monty
Post:
I purchased a 1969 27’ Overlander Land yacht this past summer. I thought It was in good shape but with every piece I remove I find three more things wrong. After pulling up three layers of carpet I found the rotting floor, then the deteriorating Black tank holder then… then…… I have gone from a good cleaning to close to a 1/2 monty. To make matters worse recently a wind storm blew down a 6’ diameter branch over my rear bath room so three panels got smashed. Here are a few questions any advice or opinions are appreciated.
Having read this forum site for a while I will articulate my parameters as follows…I purchased the Land Yacht because I like the classic exterior look of the a/s, but I am aiming for functionality and dependability everywhere else. Having said that and being of modest means and of a frivolous nature, I will attempt to use any original part if it serves my purpose and is as good or better than a newer appliance/part. I plan on taking this to the mountains on forest service roads and eventually a tour of the west, nea, maybe even Alaska with my 4 yo son, (wife is holding off on any travel commitment until final product is seen) .
Here are my questions Opine away if you like.
I took of the belly pan. Looks like I have some significant rust on the frame. Any tips for where I can weld in some re-enforcement?? Any concerns here??
Belly pan was a mess.. What is the proper replacement material for this? I only pulled off rear third so I don’t want a complete new one.
Where can I buy replacement boxes (with foam insulation ) for my black water tank? Same with my utility box. Why did these rust out?? Are they Galvanized??
Water heater is a rusted mess…is this worth savings or are modern ones better??
Same question with the furnace…
Same question on Univolt and the wwII looking fresh water pump.
Where can I get some generic aluminum trim??
Are Airstream replacement exterior skin panels worth the cost or can a metal /airplane shop produce a quality replica??
What type of insulation should I use between the fiberglass interior shell and the aluminum external shell.
I can see in some places drilling new holes into skin and braces makes for tighter fir on exterior replacements but this is not possible where two panels overlap and one is still in good shape is this correct?
I tore up the inside shell rivets pretty good, same concern here or does the fiberglass adapt to the larger rivet hole.
I have copper piping ans it is currently almost all exposed. NOW is the time to fix or replace this. There must be 4-5 places where re-enforced (threaded) rubber tubing is spliced in- between copper using screw driver clamps. Was this by original design or is it a repair due to frozen pipe damage. I like soldering but is plastic better??
Any thougts are appreciated.
Deano69LY is offline   Reply With Quote
Old 11-23-2005, 03:33 AM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
First, welcome to the forum and congradulations on the overander. I know of two members who are currently doing a total rebuild on older overlanders. You might want to read through the posts they have on their rebuilds. The posts are:
http://www.airforums.com/forum...ion-12320.html
http://www.airforums.com/forum...-me-18914.html
As far as your copper plumbing issue. You are most likely seeing is the repair of split pipes from frozen water. Most people who replace the copper go with Pex. It is a flexable pipe that offers more protection from freeze then copper. It is very easy to work with. My trailer was converted to Pex by the PO and I am very happy with it. If you search the forum for Pex you will get tons of information on the subject.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-23-2005, 05:05 AM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Looks like you have your work cut out for you!
I have a 75 that we ahve been restoring, trying to keep the original look but upgrading whre possible.
Water heaters are pretty easy to swap out. I just pulled the one out of our 76 and installed an ATWOOD, Fit in with no modifications.
Univolt, unless you like the constan HUMmmmmmmmm I'd replace it with an Inteli-Power Converter, done that to 2 out of the 3 so far. Vinatage Trailer Supply has them at a good price
Furnace? Is it rusted out? Our 73 the entire bottom was gone due to corrosion. Little more tricky but easy to come by, Suburban Furnaces, Camper World has them. Good luck!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 11-23-2005, 09:39 AM   #4
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
new parts
deano- yep, you're way beyond the just-clean-it-up-a-little stage, but sorry about the tree branch- you surely did not need that. Regards the old parts, in my opinion they are not worth saving. Check Ebay or on-line RV parts places for a new sur-flo water pump, new atwood water heater, new intellipower converter/charger, and unless you're planning on lots of cold weather camping or living I'd skip the furnace with it's ductwork and instead go with the electric ceramic heaters. This would not work for boondocking though, and I've read of some concern with the CO2 emissions from catalytic heaters- so hope other members can fill us both in on what is a safe heat with no 110 volt hookup. Search the forums for other info on belly pan material, exterior skins, rivets, etc. I had a replacement galvanized black-tank box made for me by my local hvac shop, then just used some rigid foam insulation like what was in there.While you're in there, you may want to inspect/rehab the dump valve. I just re-did my plumbing with pex, seems to be the way to go. But if you search this forum, you'll find everything you need to know and then some. Have fun and get your credit card out! -tim
tphan is offline   Reply With Quote
Old 11-23-2005, 08:45 PM   #5
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Ditto
Same thing happened to me almost two years ago when I purchased a '72 Overlander. The bright side is that once you've gone through it and fixed it, you know what you've got. It's a great opportunity to update the decor in the bath as well.
It's a long, slow process, but worth it in the end (I think).
'72 Overlander bath before
After
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-25-2005, 07:00 PM   #6
dustyrhodes
Profile:  1977 27' Overlander
Huntsville , Alabama
I feel your pain. I couldn't understand why anyone would gut their AS. What started out as a cosmetic renovation has gone full blown. The 3:1 ratio of newly discovered problems for each known problem you investigate seems about right. I would highly recommend RV discount parts outlet for any new part that you need. I plan on removing my forced air furnace and installing a catalytic heater made by a British company called Esse. They a make a firewall that looks like a framed picture with a fire burning in the center. It has an ODS and is fluelss and puts out 22,000 BTU. For the most part I also will be using ceramic heat. I also would like to install a tankless water heater as this seems much more efficient on the propane particularly after watching my current water heater in operation. Has anyone had experience with converting to a tankless heater? Good luck with your project. I totally understand.
dustyrhodes is offline   Reply With Quote
Old 11-25-2005, 08:22 PM   #7
JimmyJames
Profile:  1974 25' Tradewind
Yelm , Washington
Aluminum Trim
Aluminum Trim is available from home centers (some better than others), local metal shops have many stock items like flat, round, tube (square, round) etc. but for some really nice edge profiles, molding as well as stock stuff you can order it from Ohio. Check these sites out.
http://www.yapinc.com
http://paramountextrusions.com/endsnedg.htm
http://rds.yahoo.com/_ylt=ApfFCHbHd6...runnerent.com/
This place does nice work on counter tops with trim and retro laminates already finished and the prices are very nice. Its retro stuff.
http://www.kpetersen.com/economytables.htm#ttprice
Look at an Atwood GC6A-8 Gas & 110V Water Heater on their website.
Look at a Suburban NT-SP Series Ducted Furnace NT-30SP Furnace 30,000 BTU - 5.5 amps on their web site.
Also, the fear or frustration or angst that you are experiencing when finding all the problems, I think, is not so rare and there are lots of people as members of this group who know well those feelings. What's the saying, what won't kill you just makes you stronger. My dad used to say... mild trauma builds character. One project at a time.
Oh by the way, the copper plumbing combined with the hose clamps is a quick repair the Previous Owner (PO). The original plumbing was copper. I just finished a complete copper re- install on mine. I just put it back to original with a few upgrades it did not have before.
I wish you all the best. Your in good company !
"It takes a village to raise a silver twinkie."
-Jim Phillips
JimmyJames is offline   Reply With Quote
Old 11-29-2005, 09:44 PM   #8
Deano69LY
Thanks, several great suggestions!!!
Thanks for all the links and the welcomes. Seems like there are a lot of vendors at reasonable prices. Still would like an opinion on replacing exterior panels. Go to airstream or go to the airport shop???
Thanks again.. the more I take apart the more I learn! I bet your second airstream goes better than your first.
Old 11-29-2005, 09:46 PM   #9
Deano69LY
Good point on elec ceramic heaters...will these work on a small generator..for the bonnies??
Old 11-30-2005, 06:18 PM   #10
dustyrhodes
skins and ceramic
I plan to get my replacement aluminum at one of the local metal vendors. I have not replaced any of the skins yet, but need to patch the top skin where I removed the antena......as I am all about cable. I also have to replace the belly skin as it was torn by one of the BAL stabilizer jacks.
Sorry, I can't help you on the issue of the ceramic heater. I know they draw alot of power and I only intend to power mine with RV park power and use the catalytic heater when in the boonies.
Post pictures when you can!
Favorite Jerry-Rig? Dave Cole General Repair Forum 52 12-08-2007 01:00 AM
Carpet Squares Don in E Texas Repairing/Replacing Floor &/or Frame 1 07-04-2003 08:43 PM
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 11:25 AM
Twin rear beds DClark General Interior Topics 15 11-24-2002 09:49 PM
Full timeing Airstreem T/T/ tec12 Our Community 7 11-13-2002 02:13 PM
