Old 12-09-2015, 11:47 AM   #29
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by cwf View Post
Wow.. a new idea (not serious).. how about a 'Duct tape quilt'... it is something a 'guy' can do?
Now you've gone and done it. Letting the world know that ANYTHING CAN BE DONE WITH DUCT TAPE kills the tool gift idea for Christmas. Nice try with the (not serious) but once the gift buyers see this, we are toast. And I so wanted that new fiber optic view camera (hint, hint, hint). Pat
Old 12-09-2015, 12:24 PM   #30
PKI
PKI's Avatar
Now on to serious stuff:
A surge protector for the electrical cord. While it may never be needed and may not work like it should when it is needed, the little test button lets you trip the power so you can disconnect trailer without going to the post to kill the breaker. Remove load or power before disconnect.
As Pro said, get a 50 to 30 amp adapter. Also get a 30 to 120, a trailer 30 twist lock to a 120, and .........well, there is probably another that one too.
Get a funnel, hose reducer, water jug with spout....some way to get water into the fresh water tank. Also get a second length of hose. It's a pain to have to move the trailer a few feet when the 20ft hose is too short. It's also a pain to haul out a longer hose when it is not needed 9 out of 10 times.
Get a clear sewer section. Really helps to see that the flush has worked. Really liked that cam lock system, going to have to check that out. There are some interesting solutions to handling the black water hose. Worth researching a bit. The nitrile gloves are a bit better quality and likely more sanitary than rubber gloves unless you wash the rubber frequently. Get an use a separate hose for black water flush operation.
Get a dedicated battery water container. Distilled water comes in gallon jugs and you will never need that much. A pint or quart bottle will work. Some type of dedicated funnel is a help as well.
Get a clear coat touch up kit. Your baby will get a scratch.
Get inside and outside mats, step covers, a short handle stiff brush to clean them and big garbage bags to pack them when you can't clean them first.
Get a small grease gun and refill cartridges. If your hitch does not need to be greased, the ball does. One of those reusable grocery bags (not the paper) can be used as a cover when not towing. A big garbage bag is a good idea when you load the hitch head in the trailer or TV.
And that is just a start. The folks who have been doing this for years have lots of great solutions. Keep asking.
Now who has a solution for formed dividers that fit the curves of the overhead compartments? Certainly, that is a need that someone has filled! Pat
Old 12-09-2015, 12:34 PM   #31
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I turned the power jack head 90 degrees, and now the tailgate on my F150 opens completely (thanks, Marcel @ Balloon Fiesta). . . be careful out there, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 12-09-2015, 01:28 PM   #32
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
....One of those reusable grocery bags (not the paper) can be used as a cover when not towing....
A tennis ball works very well as a hitch ball cover to keep dirt and pant leg from contact with a greased ball. Cut a 1.5" circle and add four 1" slits 90 degrees apart to the opening and you are good to go. I use "lost tennis balls" that appear in my yard from the court nearby.
SeeMore is offline   Reply With Quote
Old 12-09-2015, 03:33 PM   #33
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Know what works even better? Neoprene sports bottle koozies turned upside down over the ball. No need to cut them like you do a tennis ball, just slip them on. But you have to get sports bottle koozies with the drawstring, not zippered beer bottle koozies. Save the beer bottle koozies for something important, such as beer.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-09-2015, 08:48 PM   #34
2013 27' FB International
olney , Illinois
awesome as usual
Pat.. got mostly all what u said except water for the batteries
( got acm's :-)
Keep it coming though.... this is really helpful
Through years of sailing and used to have a 190 B I got most of the essentials, but want to make sure..lol
Thanks Thor
2013 International 27 FB, 2010 Tundra, Centramatics, Tpi, Equalizer hitch. Selling folding bikes under ThorUSA.com and if I am not working or Airstreaming I love to sail
thorusa is offline   Reply With Quote
Old 12-09-2015, 11:15 PM   #35
gecko's Avatar
2009 28' International
Pacific Palisades , California
Great idea--gonna try it!
gecko is offline   Reply With Quote
Old 12-10-2015, 10:01 PM   #36
olney , Illinois
turning power jack on my 27 fb doesn't work, the gasbottles are way forward due to the hatch and battery access behind them ....
in fact I have to really watch what I am doing with a flag holder. The sandlapper one wouldn't work
a cause I have the big motor hanging in front of the tube and not on its side, and the door of the truck needs to be open as well
thor
Owners Manual: 1973 25' Airstream Tradewind Land Yacht - Missing Page 62>Back Cover sysgenss 1970-79 Tradewind 1 04-09-2013 09:37 PM
Revolutionary new axle installation procedure, aka what am i missing? chrisd37 Axles 54 04-15-2009 10:33 AM
Airstream Letter Decals Missing alscottfree General Repair Forum 5 03-24-2008 11:24 AM
Missing new PM? RichardT Forum Admin, News and Member Account Info 12 08-31-2007 06:45 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
