Old 06-22-2019, 07:27 AM   #1
Deb N Jon
2018 25' Flying Cloud
Waterloo , Ontario
New 2018 Flying Cloud pump/water not working
We are in the middle of a northern Ontario park and we cannot get our water to work, all we get is a LOT of air from the faucets, a few spitting, dribbles of water and not much of anything to the toilet. The pump is making a huge amount of noise, when turned on. We have previously owned a 2008 AS so not complete rookies and my husband is an all around fix it kind of guy We will be talking it into Can Am for its deficiencies but would love to use the water on this trip. Your ideas appreciated.
Deb n Jon
2018 25' RB Twin Flying Cloud
1990 VW Westphalia
1954 Heilite Pop Top camper
DebnJon is offline   Reply With Quote
Old 06-22-2019, 07:32 AM   #2
Waynesville , Ohio
water is not flowing
I’m not familiar with the Airstream, but have seen often that the winterizing by-pass valve had not been reset when winterizing was complete.
Something to check. Good luck.
doncima is offline   Reply With Quote
Old 06-22-2019, 07:35 AM   #3
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Sounds like you have air in the line. Are you hooked to a campground water supply? If so, turn that off and try opening all the faucets and then turn on the water pump.
You can try this also if not hooked to a water supply. Shut pump off, turn on all faucets, turn on pump.
Do you have water in the fresh water tank? Just asking!
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Got Connect? Turn off WiFi as WAN!!
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 06-22-2019, 11:18 AM   #4
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
You have air in the line which is before the pump. It needs to prime or capture water before it works .
Keeping the cold side of a faucets in the bath and kitchen wide open while running the pump should drive air out also try closing and opening alternating those faucets,which creates a bit o back pressure. I have found that works for me.
Laurence
LAWBC is offline   Reply With Quote
Old 06-22-2019, 11:30 AM   #5
Deb N Jon
Waterloo , Ontario
We are not connected to any campground water supply. We tried opening the faucets in bathroom and kitchen, as well, we tried alternating the opening and closing as was suggested but no water, just fizzle. There is no water in the screen on the pump. Tank is full. How does one prime? We understand the concept of priming a pump from using an old fashion well pump, but how do we do it in the AS? AND where is the by pass valve?
Deb n Jon
1990 VW Westphalia
Old 06-22-2019, 11:42 AM   #6
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Make sure the strainer is not leaking air. Are you sure you have water in the tank, and it was not inadvertently drained while traveling to your destination? Outside shower off?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 06-22-2019, 11:44 AM   #7
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Prime THIS!
Add the Camco winterization by-pass kit to the pump next opportunity. We keep a gallon of RV antifreeze handy and use it to prime the pump directly.
Camco 36543 Pump Converter Winterizing Kit TRV874795
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 06-22-2019, 02:46 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
Take the cap off the strainer and pour a cup of water in it to prime the pump.
CRH is offline   Reply With Quote
Old 06-22-2019, 03:53 PM   #9
LAWBC's Avatar
Exclamation
Something to consider , Do you have adequate water in your holding tank???
I'm thinking if it is not a air leak from the line but maybe you are pulling air from your fresh water holding tank. ????
Laurence
Old 06-22-2019, 04:01 PM   #10
kpm
2018 25' International
Mound , Minnesota
As others have said, it sounds like an air leak in the plumbing preceding the pump. This kind of leak can be difficult to diagnose and fix. If possible, connect a tube directly to the water pump and try to draw water directly from a bucket. If the pump works at that point, work backwards to the tank.
kpm is offline   Reply With Quote
Old 06-23-2019, 06:40 AM   #11
Deb N Jon
Waterloo , Ontario
Ran out of time yesterday, we will try to implement the ideas you have provided, which are greatly appreciated. I will let you know the result afterwards.
Deb n Jon
1990 VW Westphalia
Old 06-23-2019, 04:17 PM   #12
Deb N Jon
Waterloo , Ontario
So the pump is working, as we were able to get water out of a bucket but no success getting water to faucets or toilet, I guess its a trip to the dealer when we get home. Water gauge reads 75 but perhaps this is incorrect. Such a shame on a new trailer to have to do things the 'old fashion' way ....Thanks for all the suggestions!
Deb n Jon
1990 VW Westphalia
Old 06-23-2019, 08:38 PM   #13
CRH
1995 25' Excella
xxxxx , xxxxxx
Is water draining out of a low point drain?
Old 06-24-2019, 07:06 AM   #14
Deb N Jon
Waterloo , Ontario
No we had checked that, no water leakage coming from drains.
Deb n Jon
1990 VW Westphalia
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
water pump not working rusty47 Water Heaters, Filters & Pumps 3 09-21-2008 02:35 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
