Have you tried unscrewing the screens/aerator for each faucet to be sure they are not clogged. Last week on a fishing trip I still had antifreeze in the system. I hooked up to the campground water system and noticed my secondary pressure gauge was reading zero. I opened the bathroom faucets and realized my water heater was set to bypass. I fixed that and was only getting a little water flow. Time to open the WH pressure valve and air flowed through it then water. Back inside to the bathroom sink and no water. Unscrewed the aerator/screen and foamy water flowed until it cleared up. It seems to do this the beginning of Summer and it is probably sediment from the water heater. Check your bypass valves off the water to see if they are properly positioned (both pointing perpendicular out from the water heater.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
