Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 12-22-2013, 08:12 PM   #21
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Yes, it would be safe...
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 12-23-2013, 09:16 AM   #22
1988 32' Excella
Robbinsville , New Jersey
It depends on your tow vehicle for whether or not it is safe. On a 1/2 ton or SUV you could damage the suspension. On a 3/4 ton it should be OK as long as you take it easy and have good weather, I wouldn't want to try in rain or strong winds, of course some with a 3/4 or 1 ton truck never use a weight distributing hitch.
Old 12-23-2013, 04:23 PM   #23
jmcarter's Avatar
2010 28' International
Richmond Hill , Georgia
I'd definitely be hesitant about pulling it with an air suspension TV like a GL. My GL would level up my 28ft International (granted, a bit more tongue weight than your AS) but the rear axle would have been grossly overloaded. I confirmed that when I checked weights on the local CAT scales by taking virtually all the weight off my 1400!lb bars. I installed my ProPride in ~3 hours but if you're hesitant it would be worth the piece of mind to have someone tow your AS to your hitch installer.
jmcarter is offline   Reply With Quote
Old 12-23-2013, 04:42 PM   #24
2014 27' FB International
Prosper , Texas
Jmcarter, do you pull your 28' with the ML, and the ProPride.
DallasTXJoe is offline   Reply With Quote
Old 12-23-2013, 04:43 PM   #25
Prosper , Texas
I mean GL
Old 12-24-2013, 04:53 AM   #26
jmcarter's Avatar
Yes, 2013 GL350. Picture was taken prior to final hitch adjustment but it's very capable. 15 MPG towing at 65, which is about the same as I get pulling with big Cummings.
Old 12-24-2013, 07:15 AM   #27
Prosper , Texas
Good looking rig. Ours is the GL63. My towing economy will not be so stellar. Thanks for posting the pick.
Old 12-25-2013, 10:26 AM   #28
jmcarter's Avatar
I'm sure you'll enjoy the power and love the aggressive good looks of the GL63. PM me if you need any tips or lessons learned. I'm sure Sean recommended the 1400 pound bars and I can give you a ballpark adjustment until you can get to the CAT scales for fine tuning your weights. BTW, I'm using a Prodigy RF controller. Also, there are several ways to overcome blinking LED lights on your trailer if you encounter that.
Old 01-11-2014, 08:16 PM   #29
Prosper , Texas
Update: left message on phone and website for Paul. In over two weeks there hasn't been any response. May need more suggestions.
