Old 05-23-2014, 06:06 AM   #1
78SovIntl31's Avatar
1978 31' Sovereign
Paris , Ontario
Need to replace Thermostat
I think the thermostat in my trailer is shot. I have to turn it to full heat before the furnace kicks in. Once the trailer warms up and the furnace shuts off, it cycles on and off every 30 seconds.
Do i need a special type of rv thermostat, or can I go to HomeHardware and purchase a household type?
Josh Nicholson
WBCCI# 30183
78SovIntl31 is offline   Reply With Quote
Old 05-23-2014, 06:15 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
You should have a simple mechanical thermostat, before you go and buy a new one, open it up and see if the foam pad has become sticky and it causing the parts to stick. I had this issue with mine, I just removed that old pad, and cleaned up the sticky pieces and it works great.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 05-23-2014, 07:02 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is the mercury bulb type. It should be close to level to work properly.
Just a basic thermostat from the hardware store will work.
You don't by chance have a window open and the draft is causing the short cycling?
Old 05-23-2014, 08:24 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My 2001 used a mercury bulb thermostat. I replaced it with a digital Hunter that I bought from Walmart. Cost was less than $20 back at that time. Thermostat was a great improvement over the factory installed unit. Like my current Classic the thermostat was installed on a wall that was common with the refrigerator compartment. The hole for the wiring passes into the compartment which leads to air leakage. Especially if you operate the bathroom vent or stove vent fans. This leads to frequent cycling of the HVAC equipment. Be sure if you replace the thermostat to make sure that hole with the wire is sealed. I used a dab of silicone to help. Note that my Hunter did have an adjustment to control the spread in which the thermostat operates with. Some call that the maintenance band. This allows you to adjust up and down, the threshold in which the thermostat calls for heat or cooling. This allows you to compensate if the equipment is activating too quickly.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-23-2014, 08:27 AM   #5
1974 Argosy 20
Kooskia , Idaho
Get a new normal household thermostat with a battery in it. Those types (with battery) are universal and will work on the 12 volt Airstream thermostat control system. They have an internal relay which does the actual switching. They are not level sensitive. In general the AS wires will connect to the Red and white terminals on the new thermostats.
The thermostat will have a "heat-cool-off" switch. You will be using the heat and off portions.
Replace furnace thermostat with digital mhilley 2006 Safari 14 03-04-2015 11:35 AM
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Thermostat repair or bulb replace bridor15 Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2009 12:06 PM
