11-05-2017, 09:17 PM
2006 28' Safari SE
Colorado Springs
Need to replace Dometic Duo-Therm Penguin shroud
The shroud on our heat pump needs replacing. Has anyone replaced one of these and can recommend a vendor? I'd also like an idea of the price so I can shop wisely. I would also like to know if there is an option for a gray color instead of white? I'm sure I have seen someone who had that and it looked great on the Airstream.
Ken
4CU Charter Member
11-06-2017, 01:09 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
If you want the original, you can get them from Camping World.
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
11-06-2017, 06:25 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Also, I believe that all you need to do is take out four Phillips screws to remove the cover. Should take you less than 1/2 hour to replace. Best of luck.
Bob Martel
WBCCI# 5766
11-06-2017, 06:39 AM
Oswego
I got one of these back in 2012. Much more durable than the original.
http://www.icondirect.com/dometic-pe...ner-shroud-pw/
-Rich-
11-06-2017, 09:29 PM
2006 28' Safari SE
Colorado Springs
I also found the replacement shroud on Amazon Prime. Which should end up being less expensive then Camping World.
4CU Charter Member
11-06-2017, 10:09 PM
1991 34' Limited
Wichita
, Kansas
I bought one at Amazon. They offer a variety. Check it out.
Also, you can just buy a white one and a spray can of good silver paint that will bond to plastic. Krylon, Rustoleum and others make good paint that will do what you want.
Steve
11-07-2017, 04:35 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by dznf0g
Be careful buying from IconDirect, I bought one from them.
Wasn't pleased with the build quality & the fact that the AS decals couldn't be applied because of the polyethylene construction, very poor adhesion properties. After 24hrs the decals fell off in the rain.
They refused to issue a RAN and because of their being in Canada the return shipping cost was prohibitive.
Make an offer...it's still sitting in the rafters.
"You don't know where you've been until you leave, enjoy life" RLC
11-07-2017, 06:23 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Also be careful about which cover your penguin uses. I replaced mine and dealer said correct part. Part didn't have the vent holes on street side. Had to reorder.
11-07-2017, 06:30 AM
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN
, Nebraska
Shroud for heat pump
I got the model and serial # from inside the trailer by snapping out the filter cover and called Dometic. They referred me to a local supplier who had two options; one, the same as I had and another much thicker wall. I chose the later for a little over $100.
11-24-2017, 10:55 AM
2006 28' Safari SE
Colorado Springs
I'm finally getting time to swap it out and just realized the replacement (which looks to be the right size), doesn't have the vent holes toward the rear of the street side that the original does. I see on Amazon that the one with the holes (is a little more expensive) and is labeled "old style." Does that matter? Will it detrimentally affect operation?
4CU Charter Member
11-24-2017, 01:21 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Can you post a photo of your OEM....I believe the Penguin II is the one with vents.
OEM
The Penguin DuoTherm low profile OEM does not have vents.
The IconDirect I bought has none. (Still for sale $50+ the ride.)
An aftermarket shroud may very well have them.
11-24-2017, 04:02 PM
2006 28' Safari SE
Colorado Springs
Crude picture (bottom row obscured). Looks to be the same as this item on Amazon - Polar White Shroud.
4CU Charter Member
