Old 01-10-2013, 09:00 AM   #1
aquinob's Avatar
Portsmouth , Virginia
Need some quick help with toilet flange
Hey everybody. Working on pulling up the floor in the bathroom and having some problems with the toilet flange that secures the toilet to the floor. All the screws are loose but it is not budging. This is what it looks like:
Is it possible the PO somehow glued the black inner part to the top of the black water tank? Is that normal procedure? I would have thought it's just a slip fit just like what you would find in a house.
If it is glued in, what are my options? I dont want to replace the black tank, but this thing has to come up so I can replace the subfloor. Any quick help would be appreciated.
Ongoing adventures at:
https://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 01-10-2013, 09:14 AM   #2
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Send a message via Skype™ to Zeppelinium
It's threaded!!! Yes, a threaded fitting in the top of the black tank.
You have to unscrew the flange. This may also be a problem. There is a tool the slips down into the very slight slots in the black plastic. I made one from a piece of 1/4" hard plastic.
Zep
Zep@Charmedquark.net
Zeppelinium is offline   Reply With Quote
Old 01-10-2013, 09:17 AM   #3
aquinob's Avatar
Zep
Cool. I would not have thought of that. I will go give it a try right now.
Old 01-10-2013, 10:56 AM   #4
aquinob's Avatar
That was it, flange is out. Follow up question:
The water heater, what holds it in. I've got all the bolts on the outside flange removed. Are there any hidden bolts holding it down to the floor? It still has the cardboard cover and I don't want to disturb that if possible.
Old 01-10-2013, 01:47 PM   #5
1973 23' Safari
1977 23' Safari
You're done. The water heater is held in place by the face being riveted to the shell. Tug gently. Zep
Oops, don't forget the propane line.
