Old 11-29-2010, 08:53 AM   #1
2008 16' Bambi
Blairstown , New Jersey
Need service in NJ
We have a furnace issue that we cannot resolve. Too much frustration troubleshooting what is wrong so under the advice of Atwood we are looking into taking it in for service. However, we do not want to use Colonial Airstream in NJ for reasons I don't want to get into.
Does anyone know if a reliable RV service facility in the NJ/PA area?
Mightymite is offline   Reply With Quote
Old 11-29-2010, 10:40 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about more detail on what the problem is. We may be able to help.
2004 Excursion 4x4
Old 11-29-2010, 06:11 PM   #3
reo
2008 19' Safari SE
satellite beach , Florida
Atwood cust svc
Check with Atwood for a factory service center near you. We had an intermittant problem with the furnace on our 2008 and took it to a florida Airstream dealer for servive. They decided the problem was the inverter in the power supply and changed it out under warranty. It worked twice and the problem was back. We then took it to an Atwood service center where they hooked it up to some device to check out the system and within 5 minits found a faulty igniter electrode, it had a hairline crack. Problem solved, no charge.
reo is offline   Reply With Quote
Old 11-29-2010, 09:14 PM   #4
Rawfoodgirl3's Avatar
1973 23' Safari
Bethlehem , Pennsylvania
Images: 16
You might try calling Harold's RV. He doesn't sell Airstreams, but he may be able to help you. Welcome to Harold's RV
Rawfoodgirl3 is offline   Reply With Quote
Service RedSHED Off Topic Forum 0 11-09-2007 06:08 PM
Need Service Manual Help hill4th@gvtc General Motorhome Topics 0 08-31-2006 08:10 PM
Service Scott Hopkin Commercial Listings 6 04-07-2005 07:08 AM
service... canny_banjo_man Airstream Motorhome Forums 6 11-12-2002 05:52 PM
