Old 04-30-2012, 10:04 PM   #1
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
Need Loaner Tool: Olympic Rivet Shaver
Does anyone have an Olympic rivet shaver they would lend me? I'd only need it for one day and then send it right back. I'd be willing to put down a deposit. I'm an honest man and I will ensure it gets back to you the same or better than it arrived.
-Jason
jmpratt is offline   Reply With Quote
Old 04-30-2012, 10:50 PM   #2
soldiermedic's Avatar
Florissant , USA
Sometimes people clip the mandrel as close as possible and use a dremel to get it the rest of the way instead of buying the tool. It's a viable alternative if you have a small number of olympics to shave.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-30-2012, 11:06 PM   #3
jmpratt's Avatar
1969 29' Ambassador
I've done that and hand filed them as well. I'm replacing both wing windows, so I have a decent amount to do. My solution to buying the tool is to borrow the tool!
Old 05-01-2012, 05:22 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can also rent the tool. Some Airstream dealers offer this service. I have a "rental" in my toolbox.
Old 05-01-2012, 11:40 PM   #5
jmpratt's Avatar
1969 29' Ambassador
Is your rental for rent?
Old 05-02-2012, 05:09 AM   #6
Well Preserved
1993 21' Sovereign
The rental can be rented, but you would have to call the dealership where I work to rent it.
I am not allowed to tell you where I work or post any links, but it is in Colfax, NC.
Old 05-02-2012, 06:52 AM   #7
Lothlorian's Avatar
Loganville , Georgia
Here is the thread I posted. I used a concaved dremel grinding bit on my harbor freight dremel knock off. It worked great. They came out perfect. I paid under about $14.00 for the grinder and $4.00 for the grinding bit. The whole thing took me about a couple of hours.
http://www.airforums.com/forums/f109...-70006-24.html
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 05-03-2012, 08:18 AM   #8
jmpratt's Avatar
1969 29' Ambassador
Did the aluminum clog the grinding bit?
Old 05-03-2012, 08:58 AM   #9
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I used a Dremel and a flap wheel sander 80 grit. I thought it did a decent job. Clip the mandrel down close as you can to the rivet.
Amazon.com: Dremel 502 3/8" Flapwheel Sander, 80 grit: Home Improvement
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-03-2012, 09:18 AM   #10
Lothlorian's Avatar
It was like cooking. Went low and slow. The aluminum wears down like butter melting. The bit did not clog. Looked great
Brian
Brian & Adrienne
