Old 09-19-2015, 05:40 PM   #1
1970 27' Overlander
paris , Tennessee
Need inspecting tips
I'm looking at a 1970 overlander that has been sitting for the past 15 years. I could use any advice that anyone can give me about what to look for when inspecting it. I do know that the floor is a bit "spongy" under the windows in the front and rear. Thank you in advance for any help you can give me. Steve
steve102462 is offline   Reply With Quote
Old 09-19-2015, 05:59 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Portal page, right hand column, near the bottom is a link to a detailed inspection checklist.
mimiandrews is online now   Reply With Quote
Old 09-19-2015, 06:04 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
http://www.airforums.com/forums/f138...ist-43294.html
MICHAEL
Old 09-19-2015, 08:57 PM   #4
1970 27' Overlander
paris , Tennessee
Thank you
Old 09-22-2015, 10:39 PM   #5
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Expect the smell of mice. After sitting that long, they have probably made a AS condo by now. Just a heads up.
Cyquest is offline   Reply With Quote
Old 09-23-2015, 07:53 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have come to the conclusion that ALL Airstreams over ten years old have at least some floor rot. It is the nature of the beast.
Brevi tempore!
Old 09-23-2015, 09:57 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Use an icepick to probe the floor to see how punky it is. At the bottom of closets and cabinets is a good place to look., especially bathroom and galley. Expect the axles are probably shot, but you can check by observing if there is tire showing above the rim in the wheel well, if the torsion arms have a downward angle or are at least level and if you jack up the axles by the plate between the axles if the wheels stay on the ground while the body is jacked up a few axles. A serious problem on the longer 70s is rear end separation. If you stand on the rear bumper and bounce you should see no or little independent movement of the bumper relative to the body. Expect all appliances will need to be replaced especially the furnace.
Need help inspecting Trailer in Phoenix! East Wynd Buyer Guidelines 6 01-15-2015 10:47 PM
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
Inspecting '71 Overlander.. Axles and more streamahead Axles 12 09-16-2010 01:51 PM
Walking on the roof - cleaning / inspecting Resorts Roof 24 08-11-2008 05:03 PM
inspecting an old Airstream jpeterman General Repair Forum 6 07-25-2008 06:43 PM
